ROOF RADIO ANTENNA MOUNT AND MAST
If you're looking for a specific Caprice PPV-related part, service, or car post your requests here.
2822MM
Post by 2822MM » Tue Jan 05, 2021 3:45 am
I need the factory radio antenna mount on the roof.
shawnjon82
Re: ROOF RADIO ANTENNA MOUNT AND MAST
Post by shawnjon82 » Tue Jan 05, 2021 2:46 pm
What year of car do you have?
Ilikemtb999
Post by Ilikemtb999 » Wed Jan 06, 2021 4:05 pm
I have one from my 2014.
2822MM
Post by 2822MM » Thu Jan 07, 2021 5:46 pm
It’s 2013, but they are all
the same which is good.
Post by s/c'd cav » Fri Jan 08, 2021 4:02 pm
the base on the 11 is a 1 year part # , 12-13 are the same # , 14-17 are the same
the mast is 11-13 , then 14-17
so they are not all the same
2822MM
Post by 2822MM » Sun Jan 10, 2021 8:26 pm
Thank you for clarifying. I stand corrected. I actually won’t be needing the parts. My radio works fine without it which is odd. I noticed the radio antenna is attached to rear window.
Post by s/c'd cav » Sun Jan 10, 2021 9:09 pm
that was done by the upfitter , ive seen a few like that , they use the stock antenna for their gear
2822MM
Post by 2822MM » Sun Jan 10, 2021 9:45 pm
Your absolutely right. The shark fin replacement on my roof has cut wires with gps, 5G, etc labeled on them so you are correct. Glad at least radio is operative.
Post by s/c'd cav » Sun Jan 10, 2021 9:57 pm
i did forget to mention the rear glass is the OE with the antenna in it , its just not used normally
