Page 1 of 2
Auxiliary battery components
Posted: Sun Mar 25, 2018 11:11 pm
by HoldenPPV
Looking to buy a few pieces to upfit to the optional auxiliary battery to my 2012 9C1. Parts wanted fit 2011-2013 and are:
Auxiliary battery Hold Down Strap - GM (92258821)
Hold Down - GM (92199344)
Hold Down Clamp Bolt - GM (11589404)
Re: Auxiliary battery components
Posted: Mon Mar 26, 2018 10:57 am
ThirdGenFarmer had most of that available back in December. PM him to see if he still has them.
Posted: Tue Mar 27, 2018 8:53 pm
by HoldenPPV
Hey thanks Gene, I’ll do that. Appreciate it the info!
Posted: Fri Mar 30, 2018 12:28 am
by 9C1fanatic
If he doesn't, Ill check the garage, I have the set from my 2014 but I would have to confirm part #s. No idea if that set up changed over the years. Let me know.
Posted: Fri Mar 30, 2018 10:35 pm
by HoldenPPV
Yes that’d be great I still need those parts. ThirdGenfarmer has not responded but I am wondring if my PM’s are going through as I have sent a coulple and gotten no replies.
Posted: Sat Apr 07, 2018 5:46 pm
by 9C1fanatic
Pm me and let me know if you need them
Posted: Thu Apr 12, 2018 10:13 pm
by HoldenPPV
I have PM’d you. Thanks!
Posted: Fri Apr 13, 2018 8:58 am
by GTPprix
FYI Aux battery also typically requires BCM programming.
Posted: Fri Apr 13, 2018 11:12 am
by kevink
GTPprix wrote:FYI Aux battery also typically requires BCM programming.
That's interesting. Does removing the aux battery require BCM programming? I have removed mine and nothing weird has happened.
Posted: Tue Nov 13, 2018 4:09 pm
by cerbomark
Me too.
