So I recently got this console kit and put them on.
Now could any one tell me where and which would be the 1300 W power cable that was mentioned in the user manual?
Posting updates and questions about Havis Console
- QQ图片20180309003028.jpg (190.11 KiB) Viewed 13290 times
Re: Posting updates and questions about Havis Console
Well I can tell you where the battery wire plugs into. Weather you have anyting plugged into it on your car is a crap shoot.
So on the passenger side you remove the kick panel and you will see a bunch of wiring harnesses. The blue plug with the red and white wire is the main battery feed from the auxiliary battery. In the connector marked 1A you got two power wires and the wires that activate the relays that power those power wires at the aux battery. SO if you got a wire plugged into the blue connector follow it to see what it is plugged into. Chances are it's cut and taped up.
1300 Watts?!? Wow.
