It is currently Wed Jan 24, 2018 10:39 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Afm disabler
PostPosted: Mon Sep 25, 2017 8:08 pm
Offline
Has anyone used an afm disabler and if so any issues with them, i recently put a axel back exhaust on mine and it sounds great when its running on all 8cyl but 4cyl mode sounds well like a 4cyl with an exhaust would.
Top
 Profile
 Post subject: Re: Afm disabler
PostPosted: Mon Sep 25, 2017 8:51 pm
Offline
One member tried it says it works good:
viewtopic.php?f=14&t=1566&p=17298&hilit=afm+disable#p17298
_________________
Top
 Profile
PostPosted: Tue Sep 26, 2017 4:48 pm
Offline
Would seem like a waste of money considering it does only the one thing and you already have a better exhaust on. Why not just get a tune for entire car, both ECM and TCM are going to get modified and then you can enjoy more than just the better sound. On the handheld device I have I was able to get multiple octane tunes that are switchable in a manner of minutes and I'm sure you could have a AFM on/off one done if that's your goal also. Otherwise with that kind of miles you have nothing to worry about unless the engine idle hours is super high. I installed a LS3 OEM cam on my car with 20k and am continuing to use and benefit from the AFM, most all of the failures of these across the GM lineup are on high miles engines with questionable oil change intervals or extended idle. The computer engine oil life monitor system on my car has never gone below 60% and I religiously change oil at 6months regardless of miles I fear tons of owners are out there running standard oil for well over a year.
Top
 Profile
PostPosted: Thu Sep 28, 2017 8:41 pm
Offline
But until you either get the disabler or a tune, you can unplug the vacuum sensor on the brake booster. Of course you'll get the SES light but you'll know what it's for. I've done it on mine, works fine. This sensor is solely for the AFM system.
Disabler seems like a waste of money. I'd just get a tune. Better bang for the buck.
_________________
Top
 Profile
Search for:
Jump to:
