2013 PPV SPIL Translation
Posted: Mon Nov 19, 2018 6:43 pm
My intellectual curiosity has the better of me and I can't seem to find what some of my codes mean.
Can anybody help out? I'll keep this list edited and updated as you all respond. Thanks much!
2013 Caprice PPV
QRRGNR / IEK19
AAP - FLEET INCENTIVE US INVESTIGATION SERVICES (D/W/3A/3Z - TRK STUX)
ACC - Seats, front bucket, cloth with heavy-duty foam, vinyl rear bench, includes seatback A -- security panel and vinyl floor covering
AH7 - Seat Adjuster, power front passenger 4 way
AKC - Airbags, Dual stage frontal thorax side-impact driver and front passenger w/passenger sensing system
AKP - Window type solar absorbing
AKX - Windshield type solar absorbing
AL5 - Sensor indicator inflatable frt pass presen detector
AQ9 - Seats, Front bucket
ATG - Remote keyless entry
AU7 - KEY COMMON, FLEET
AXJ - Passenger car
A6G - Seat adjuster, driver 8-way power
A98 - Trunk release, ignition controlled
BDR - Lock cylinder, trunk
BIJ - Cluster Color inst
BW4 - Molding B/S (opel) extr, mldg, side window reveal, chrome
CJ2 - Air conditioning, dual-zone automatic climate control
CNZ - Module enhanced blower control
DD4 - Mirror, inside rearview with compass
DNS - Dealer installed indicator
DP2 - Mirrors, outside power-adjustable, Black
D72 - Door handles, Black
EF7 - Country code, U.S.A. America (USA)
ERR - TRIM SEAT FRT ST CLOTH - ECLIPSE/RR ST VINYL - COMPANION
ESA - Plant Code
EVG - Equipment engine, V8
E2C - Order to Delivery - expedite
FE9 - Emissions, Federal requirements
FHS - Vehicle fuel gas E85
FLT - Fleet processing
FMP - TRIM DOOR FRT DR - COMPANION MAT / RR DR - MINI PERF
GII - PRIMARY COLOR EXTERIOR, HERON WHITE
GW8 - Rear axle, 2.92 ratio
G80 - Differential, limited slip
I13 - ENGINEERING YEAR 2013
JFA - BRAKE PARKING,FOOT APPLY
JL9 - Brakes, 4-wheel antilock, 4-wheel disc, heavy duty
KD1 - Transmission oil cooling sys
K12 - Shift knob, urethane
KTB - AUDIO INTERFACE WIRELESS
KTZ - KIT, TIRE INFLATOR NONE
KW7 - Alternator, 170 amps with idle boost
K4S - Battery, auxiliary, 600 cold-cranking amps
LHD - Left hand drive
L77 - Engine, 6.0L V8 SFI
MAH - MARKETING AREA NORTH AMERICA
MDC - Molding B/S upper bright
MX0 - Transmission, 6-speed automatic
MYC - Transmission, 6 spd automatic
NT7 - Federal emissions system
N10 - Exhaust system, dual, stainless-steel
N40 - Steering, power, rack-and-pinion
N46 - Steering wheel, 4 spokes
RT3 - Wheels, 18" (45.7 cm) heavy-duty steel
R5M - Tires, P235/50R18 all-season blackwall
R5Z - TIRE SPARE P235/50R18 XL 99W BW AL3
R6D
R9N - Processing code-seat
SG8 - WHEEL SPARE 18 X 8.0, J, STEEL, DESIGN 1
TVU - HANDLING CHARGE ELIZABETH ASM TO KERR INDUSTRIES, BENICIA PORT, CA
T3W - Daytime Running Lamps
T4A - Headlamps, halogen
UBW - Audio system, AM/FM stereo with CD player and MP3 playback
UDC - Driver Information Center
UJ6 - Tire Pressure Monitor System
UQF - Audio system feature, 4-speaker system
U71 - Antenna, roof-mounted
VK3 - License plate bracket, front
VQ2
VVQ - Calibration daytime running lamps
VZD - VIN MODEL YEAR 2013
V8D - VEHICLE STATEMENT US
WL9 - MODEL CONVERSION POLICE CAR
XL7 - Frequencies Rating 315MHZ, long distance
XR5 - FILTER POLLEN
YK1 - IDENTIFICATION EFFECTIVE POINT CONTROL- NOISE REDUCTION
02D - TRIM COLOR SEAT ONYX
1A6 - TRIM COLOR DR PANEL ONYX
1SB - PACKAGE-OPTION 02
1SZ - Option package discount
4BB - INTERIOR TRIM ONYX
6A3 - Floor covering, heavy-duty vinyl
6E3 - Door locks, single key locking system, entire fleet coded alike
6J1 - Ignition, 110-amp
6N5 - Window switches, rear-window inoperative
6N6 - Door locks and handles, inside rear door inoperative
6X1 - COMPONENT FRT LH NON-COMPUTER SEL SUSP
7B3 - Suspension, Heavy-Duty Police
7X1 - COMPONENT FRT RH NON-COMPUTER SEL SUSP
7X6 - Spotlamp, driver-side
8X2 - COMPONENT RR LH NON-COMPUTER SEL SUSP
9C1 - SEO VEHICLE, POLICE CAR
9X2 - COMPONENT RR RH NON-COMPUTER SEL SUSP
CC/HC
WA-679 - Heron White Paint
Edit 1 - Updated most of these using: http://d354nuoz4t18d4.cloudfront.net/b0 ... 1497380755" onclick="window.open(this.href);return false; [These are all denoted in ALL CAPS]
Edit 2 - There's a few outlier ones that I can't seem to find at all!
Edit 3 - Thanks to s/c'd cav for 2 more!
2013 Caprice PPV
QRRGNR / IEK19
AXJ - Passenger car
ESA - Plant Code
R6D
VQ2
XR5 - FILTER POLLEN
CC/HC
