2013 PPV SPIL Translation
My intellectual curiosity has the better of me and I can't seem to find what some of my codes mean.
Can anybody help out? I'll keep this list edited and updated as you all respond. Thanks much!
2013 Caprice PPV
QRRGNR / IEK19
AAP - FLEET INCENTIVE US INVESTIGATION SERVICES (D/W/3A/3Z - TRK STUX)
ACC - Seats, front bucket, cloth with heavy-duty foam, vinyl rear bench, includes seatback A -- security panel and vinyl floor covering
AH7 - Seat Adjuster, power front passenger 4 way
AKC - Airbags, Dual stage frontal thorax side-impact driver and front passenger w/passenger sensing system
AKP - Window type solar absorbing
AKX - Windshield type solar absorbing
AL5 - Sensor indicator inflatable frt pass presen detector
AQ9 - Seats, Front bucket
ATG - Remote keyless entry
AU7 - KEY COMMON, FLEET
AXJ - Passenger car
A6G - Seat adjuster, driver 8-way power
A98 - Trunk release, ignition controlled
BDR - Lock cylinder, trunk
BIJ - Cluster Color inst
BW4 - Molding B/S (opel) extr, mldg, side window reveal, chrome
CJ2 - Air conditioning, dual-zone automatic climate control
CNZ - Module enhanced blower control
DD4 - Mirror, inside rearview with compass
DNS - Dealer installed indicator
DP2 - Mirrors, outside power-adjustable, Black
D72 - Door handles, Black
EF7 - Country code, U.S.A. America (USA)
ERR - TRIM SEAT FRT ST CLOTH - ECLIPSE/RR ST VINYL - COMPANION
ESA - Plant Code
EVG - Equipment engine, V8
E2C - Order to Delivery - expedite
FE9 - Emissions, Federal requirements
FHS - Vehicle fuel gas E85
FLT - Fleet processing
FMP - TRIM DOOR FRT DR - COMPANION MAT / RR DR - MINI PERF
GII - PRIMARY COLOR EXTERIOR, HERON WHITE
GW8 - Rear axle, 2.92 ratio
G80 - Differential, limited slip
I13 - ENGINEERING YEAR 2013
JFA - BRAKE PARKING,FOOT APPLY
JL9 - Brakes, 4-wheel antilock, 4-wheel disc, heavy duty
KD1 - Transmission oil cooling sys
K12 - Shift knob, urethane
KTB - AUDIO INTERFACE WIRELESS
KTZ - KIT, TIRE INFLATOR NONE
KW7 - Alternator, 170 amps with idle boost
K4S - Battery, auxiliary, 600 cold-cranking amps
LHD - Left hand drive
L77 - Engine, 6.0L V8 SFI
MAH - MARKETING AREA NORTH AMERICA
MDC - Molding B/S upper bright
MX0 - Transmission, 6-speed automatic
MYC - Transmission, 6 spd automatic
NT7 - Federal emissions system
N10 - Exhaust system, dual, stainless-steel
N40 - Steering, power, rack-and-pinion
N46 - Steering wheel, 4 spokes
RT3 - Wheels, 18" (45.7 cm) heavy-duty steel
R5M - Tires, P235/50R18 all-season blackwall
R5Z - TIRE SPARE P235/50R18 XL 99W BW AL3
R6D
R9N - Processing code-seat
SG8 - WHEEL SPARE 18 X 8.0, J, STEEL, DESIGN 1
TVU - HANDLING CHARGE ELIZABETH ASM TO KERR INDUSTRIES, BENICIA PORT, CA
T3W - Daytime Running Lamps
T4A - Headlamps, halogen
UBW - Audio system, AM/FM stereo with CD player and MP3 playback
UDC - Driver Information Center
UJ6 - Tire Pressure Monitor System
UQF - Audio system feature, 4-speaker system
U71 - Antenna, roof-mounted
VK3 - License plate bracket, front
VQ2
VVQ - Calibration daytime running lamps
VZD - VIN MODEL YEAR 2013
V8D - VEHICLE STATEMENT US
WL9 - MODEL CONVERSION POLICE CAR
XL7 - Frequencies Rating 315MHZ, long distance
XR5 - FILTER POLLEN
YK1 - IDENTIFICATION EFFECTIVE POINT CONTROL- NOISE REDUCTION
02D - TRIM COLOR SEAT ONYX
1A6 - TRIM COLOR DR PANEL ONYX
1SB - PACKAGE-OPTION 02
1SZ - Option package discount
4BB - INTERIOR TRIM ONYX
6A3 - Floor covering, heavy-duty vinyl
6E3 - Door locks, single key locking system, entire fleet coded alike
6J1 - Ignition, 110-amp
6N5 - Window switches, rear-window inoperative
6N6 - Door locks and handles, inside rear door inoperative
6X1 - COMPONENT FRT LH NON-COMPUTER SEL SUSP
7B3 - Suspension, Heavy-Duty Police
7X1 - COMPONENT FRT RH NON-COMPUTER SEL SUSP
7X6 - Spotlamp, driver-side
8X2 - COMPONENT RR LH NON-COMPUTER SEL SUSP
9C1 - SEO VEHICLE, POLICE CAR
9X2 - COMPONENT RR RH NON-COMPUTER SEL SUSP
CC/HC
WA-679 - Heron White Paint
Edit 1 - Updated most of these using: http://d354nuoz4t18d4.cloudfront.net/b0 ... 1497380755" onclick="window.open(this.href);return false; [These are all denoted in ALL CAPS]
Edit 2 - There's a few outlier ones that I can't seem to find at all!
Edit 3 - Thanks to s/c'd cav for 2 more!
2013 Caprice PPV
QRRGNR / IEK19
AXJ - Passenger car
ESA - Plant Code
R6D
VQ2
XR5 - FILTER POLLEN
CC/HC
- 2013 PPV SPIL
- IMG_6664.JPG (118.04 KiB) Viewed 20499 times
Re: 2013 PPV SPIL Translation
they are RPO codes , regular production options
the WA code is the paint code , in your case heron white
Yup, tracking what they are. Just have a few left that I can’t find out what they are.
Thanks for the reply.
YK1 IDENTIFICATION EFFECTIVE POINT CONTROL- NOISE REDUCTION
TVU HANDLING CHARGE ELIZABETH ASM TO KERR INDUSTRIES, BENICIA PORT, CA
the other 2 codes do not show up for your VIN# , so not sure what they are
Sweet, thanks!
What site did you use to look this up by chance?
my work computer , lol
i work at a chevy dealer in the parts dept
Oh nice, any chance you can send me over the printout or original sticker??
that is something i do not have access to
your build date is feb 5 2013
Ok no problem, much obliged!
I've put together a spreadsheet where you can enter your codes from your SPIL (Service Parts Identification Label). Once you enter your codes... kind of a pain but the payoff is nice, you get all (almost all) of the descriptions. This is the resulting (example) report from my car in PDF format. You can create one just like it for your car: https://drive.google.com/file/d/1Z9ja0F ... sp=sharing
Here's the Excel spreadsheet on my google drive - instructions are in the top of the spreadsheet. Be aware that "I" and "1" are easily confused in your codes. If you get a "Not Found", try the opposite ("I" or "1"): https://drive.google.com/file/d/1MLH5wW ... sp=sharing
Once you click on the spreadsheet, click on the "down arrow" in the upper right of the site.
I hope you enjoy. If you have any comments or thoughts on how to improve, please post!
John
John
