Ill post the dyno sheet tonight. Unfortuanetly my home computer blocks this site, so Ill post a photo of it later from my phone. Exhaust was open and do you mean at what RPM did it make that power?kevink wrote:Where did it make 434, and was that with open exhaust? Can you post the dyno sheet?
Big N/A cam and dod delete
Re: Big N/A cam and dod delete
Cool, thanks a lot! Yes, I was wondering about RPM.S13REMI wrote:Ill post the dyno sheet tonight. Unfortuanetly my home computer blocks this site, so Ill post a photo of it later from my phone. Exhaust was open and do you mean at what RPM did it make that power?kevink wrote:Where did it make 434, and was that with open exhaust? Can you post the dyno sheet?
Car is shifting at 6750 makes all the power up top. Ill let the graph do the talking latter.kevink wrote:Cool, thanks a lot! Yes, I was wondering about RPM.
When you or anyone has done one of these big cams are you addressing the OEM rocker bearing failure with one of these upgrade kits or using a aftermarket rocker?
http://www.ebay.com/itm/Competition-Cam ... OK&vxp=mtr" onclick="window.open(this.href);return false;
Migs- When installing a cam, you definitely want to install a trunion kit. I would even install them in a stock application as the needle bearings have a tendency of coming out of the cages and destroying engines. There's a guy on the SS forum that had a relatively low mileage failure on a stock engine.xcidmigs wrote:When you or anyone has done one of these big cams are you addressing the OEM rocker bearing failure with one of these upgrade kits or using a aftermarket rocker?
Whatever you do, don't get the Comp kit. There seems to be as many failures as installations. I would go with Straub, which gets rid of the needle bearings all together. CHE also makes a bushed kit, but it doesn't seem as nice as the Straub kit in my opinion. This is a big thread, but worth the read. The CHE kit is discussed near the end of the thread. Post #9 shows what happens with the Comp kits.
http://ls1tech.com/forums/generation-ii ... -kits.html
The stock rockers are actually very strong, so there's no need to replace them in most situations.
http://www.straubtechnologies.com/ls-bu ... nion-kits/" onclick="window.open(this.href);return false;
Does look good and just a slight cost increase to get rid of the bearings completely
Here's the dyno graph. Makes peak power at about 6250rpms
- IMG_2222.JPG (1.45 MiB) Viewed 21402 times
Any idea why the giant drop off at 6500? Are you using a stock type MAF?
That's where it shifted. I had mentioned in the first post HPtuners would no longer lock the car in 4th gear. So that was a 3rd gear pull and the dip is tbe car shifting in to 4th
How's your transmission handling the power. I recently did my dod delete,cam,intake,long tube to cutouts and am curious if you've had to add a cooler or anything like that.
- 2019-02-27 18.18.17.jpg (3.88 MiB) Viewed 15986 times
