Pulley replacement
white12
Pulley replacement
Post by white12 »
Hey, so I'm new to the forum and just as new to chevy products. I've been searching older posts but haven't found a clear answer.
My crankshaft pulley (harmonic balancer i guess...) has a pretty good wobble, so it needs replacing. And if it needs replacing it needs upgrading. I found a few on summit but not sure on quality. Anyone have links to a better pulley? L8ghter would be great. Possibly underdrive.
Re: Pulley replacement
Post by xcidmigs »
There is a TSB on those depending on the year, obviously a bad GM part I had mine done 10K miles ago no wobble still...
kevink
Post by kevink »
Powerbond's 25% underdrive balancer works great on my car. I have no charging issues, but my idle is pretty high at 800-900 RPM. Part# PBU1117-SS25.
white12
Post by white12 »
TSB? I'm not familiar with the term.
I saw the powerbond at summit. I may go with their own then, since it's about 1/3 the cost. Has the underdrive made enough of a gain to justify the money?
kevink
Post by kevink »
white12 wrote:TSB? I'm not familiar with the term.
I have no idea on power gains since I changed a lot of parts at once, but if it's a 5-10 HP gain as some say, it's a good value in terms of dollars per HP. If you can find a used one, it's an even better deal. I think I paid just over $100 for mine.
$10 per HP is the going rate for aftermarket replacement parts updates. So if they claim 10 HP, and charge about $100, then you are on par. Try to find reviews where others have at least tried dyno tests, though, just to be sure.
I have an underdrive crank pulley on our 96 SS though, and can attest it helps. I’d do the same if we needed a replacement on the 9C1.
white12
Post by white12 »
If its only 100 then it's definitely worth it. Summit was charging 230. I'll see if I can find it elsewhere.
Post by Pursuit »
TSB stands for Technical Service Bulletin. All of the manufacturers will release these as a "description/fix" of an acknowledged problem. There are searchable sites for TSB's. I apologize for not having that available..
Regards,
Post by xcidmigs »
If your car qualifies for the TSB then any GM dealer does the replacement for free.
On the under drive pulley scene how would installation work with the factory belt? and I don't understand why it would effect idle since that's a PCM function. I've always heard that the prob with them is unsteady IDLE volts from the alternator since the idle is the same but the RPM of the belt is actually slower meaning it turns the alternator pulley slower?
kevink
Post by kevink »
That's right, they turn the alternator slower, but since my idle is set higher than stock, my alternator speed should be back at stock speed at least. With the Powerbond pulley, you need to use shorter belts. I have the numbers somewhere if anyone needs them.
