Engine hours on 2014 6.0
Posted: Wed Oct 03, 2018 5:06 pm
by Jungle867
Is there a way to see the engine hours on the 2014 model year? I have tried finding it through the DIC like on the 2011 model but it seems the option doesn't exist on the 2014.
Re: Engine hours on 2014 6.0
Posted: Wed Oct 03, 2018 8:01 pm
by Sanford
Don't own a 2014, but if it is like a 2013, I believe you can go into the settings in the DIC and it can be turned on so it will be displayed when you scroll through the DIC.
David
Posted: Thu Oct 04, 2018 10:38 am
you select it using the button ,and rotating the up down , on the turn signal lever
Posted: Fri Oct 05, 2018 12:50 pm
by Jungle867
I figured it out.
To view engine hours, you must make them available through the infotainment system. Once doing so, you are able to see them in the DIC.
