So, when I bought my '11, it had already been deleted. Running a little lunati cam with btr .660 springs. The previous owner
told me the rockers were stock and didn't know the pushrod length. The car runs well, but, has a fair amount of chatter/sewing machine sound. I'm going to pull the valve covers to check preload this weekend and see if I need to swap the pushrods out for a different size. I figured while I'm in there, it would be a good time to swap rockers.
There are about a million choices from what I've found online, so I wanted to ask some of you guys what you're running/if there is a decent set out there under the $500 mark that are a worthwhile upgrade?
Rocker arm upgrades
Re: Rocker arm upgrades
Just an opinion, but unless plans are to spin the thing up past 7000, the OE rockers with a bushing upgrade is probably best option. Newest thing I've seen is a shaft setup from COMP, which still uses OE rocker arms--and won't be under $500.
https://www.enginelabs.com/engine-tech/ ... s-engines/" onclick="window.open(this.href);return false;
I read up last night a bit about the trunion upgrade, I'm a little green to say the least when it comes to LS based engine mods. Before this car, my last "toy" had a SBC in it. So, I'm learning alot with this thing as I go.
Note that a fair amount of that 'sewing machine' sound comes from the accessory drives and injectors. Our '12 is factory stock and sounds like a Singer under the hood.
There is no reason to replace the rockers for your application. The stockers are actually great as long as you use a bronze trunnion upgrade to get rid of the needle bearing that have a habit of failing and circulating through your engine.
For a rocker arm upgrade, Straub makes a kit that seems to have a decent amount of favor.
If you do an upgrade, I would aim to get one that gets rid of the needle bearings personally.
Straub is only okay. I had to get three different sets before I got one that was usable. I am seriously questioning the quality of the Straub set and would never buy another one of his kits. The machining on the brass bearings is horrible, yet still considered "normal" by Straub.
Manton recently started making one kit that looks amazing. Manton is an awesome company that makes killer parts. If I had to get another trunion kit, it would definitely be from Manton.
Good info thanks for the counterpoint.
Time for some more research for me...
EDIT: link to mentioned Manton (knew the name sounded familiar, they do a bunch of parts for diesel applications as well...)
http://rollerrockerarms.com/ls-billet-t ... nnion-kit/" onclick="window.open(this.href);return false;
