check engine light high voltage from oil pressure switch?
lastcall190
Re: check engine light high voltage from oil pressure switch?
Post by lastcall190 »
Try 12585328 for the screen and 12673134 for the sensor itself (the sensor PN will list 2015+ PPVs on gmpartsdirect, but I used it anyhow... just an FYI)
jj55chevy
Post by jj55chevy »
camrat68 wrote: Wed Feb 13, 2019 12:09 pm Does anybody have a part number-either GM or parts store-for the sensor and screen? I tried finding it on GMPartsDirect with no luck.
Thanks,
Jim
I bought the sensor from O'riely's . The brand name is standard and the part number is PS508
SS396ELKY
Post by SS396ELKY »
Thanks,
Jim
ACDelco switch: 12673134
Doorman filter: 917-143
SS396ELKY
Post by SS396ELKY »
jj55chevy wrote: Tue Feb 12, 2019 6:25 pm yikes!! mine wasn't that bad...but you gotta admit, it's a cheap cure!
Yes it was... However ACDelco sure was proud of that switch...$65.65 + Tax... $4.84 for the filter...
Whoever said it was easy to change out must have broke the connector trying to remove it... That was the pain in the ass portion....
119C3NJ
Post by 119C3NJ »
35 on Amazon for ac delco OP sensor.
1995 MG5 Yukon GT Black
119C3NJ wrote: Thu Feb 14, 2019 10:25 pm 35 on Amazon for ac delco OP sensor.
Yes. Friends don't let friends buy parts at the Stealership!
119C3NJ
Post by 119C3NJ »
Moose I work at dealer, I know GM prices are crazy. I always shop around. Amazon is actually cheaper then GM cost to dealer.
i only deal with crook auto , or scamazon , as a last resort , ill stick to my GM employee prices , as do most of my friends
camrat68
Post by camrat68 »
Thanks for the part numbers!!
I couldn't find those to save my life. :D
Jim
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
119C3NJ
Post by 119C3NJ »
12673134 for OP sensor
12585328 for screen
I think it was a 26mm deep socket
