Cold weather issues?
camrat68
Post by camrat68 » Mon Feb 04, 2019 8:16 pm
Recently in Central WI we had two days of -26* actual temp not wind chill.
The second day my Wife told me that her '12 PPV started throwing check engine codes on start-up after work.
The codes are
P0523 engine oil pressure
P1516 throttle actuator control
P2101 throttle actuator control
P0442 evap emission system
We have an OTR-CAI intake installed and I've run into issues on my '95 with throttle blades freezing into position with a similar short intake tract. Everything seems to be working OK and it drives fine although she said it initially ran rough. I'm just wondering if it's safe to drive roughly 60 miles a day like this until I can clear the codes?
Thanks,
Jim
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
2013 Black/White 9C1--NADACOP-Stock. For now......
SS396ELKY
Re: Cold weather issues?
Post by SS396ELKY » Thu Feb 07, 2019 2:39 am
I'm interested to see where this goes... This morning here in KS it was cold about 19 degrees and misting, my 2012 PPV popped a P0523 code... No other codes were displayed... After a quick google search I read where this could be a number of problems...
1. Faulty Switch
2. Wrong oil
3. Clogged switch filter...?
4. Bad wiring
5. Bad CPU (Not)
Where is this switch located...?
Thanks in advance...
lastcall190
Post by lastcall190 » Thu Feb 07, 2019 11:28 am
Located behind the intake manifold close to the driver's side edge. Unplug the connector and then a long socket to loosen (cant recall size off top of my head)
!DOD : LS9 Cam : Pat G : Magnaflow : VCM
168k and going strong
Post by Mooseman » Thu Feb 07, 2019 3:31 pm
For #3, under the oil pressure switch, inside the port, there is a small screen filter. It can be cleaned if not damaged when pulling it out with a dental pick or can be replaced.
This video shows it very well. Cued to the actual job as he talks a lot about the why's and reasons for replacing the filter with the sensor. Use part numbers for your car (he talks about a sensor and a switch, ours is a sensor). This is on a FWD so the motor is sideways. Imagine it in your RWD. It's a tight area to work in.
2011 Caprice PPV, 1 of possibly 4 in Canada!
