TSP AFM Cam?
Numbah1
TSP AFM Cam?
Post by Numbah1 »
Has anyone swapped a TS&P cam with the AFM? Or has anyone seen a thread of it? Ive been doing research as im trying to get 370whp about these and only 2 places have been the Hot Rod article where they cheated, and 1 single mention on Camaro5 where they said someone else gained 20whp. I cant be the only guy whose looked into this. Im just wondering how much of an increase a L77 would get
Re: TSP AFM Cam?
Post by xcidmigs »
What are the specs of the cam you are looking at? There is multiple people running cams with the DOD system still in place and functioning normally, I have a OEM LS3 and its tuned for 93 octane which was rated to what 430 HP in a stock camaro/vette?
Numbah1
Re: TSP AFM Cam?
Post by Numbah1 »
https://www.texas-speed.com/p-8501-tsp- ... -cams.aspx
They dont give any real spefics, just that it makes .500 lift lol i didnt know that we could use the AFM lifters for a regular cam
kevink
Re: TSP AFM Cam?
Post by kevink »
That cam is for the L99 engine that has variable cam timing.
Numbah1
Re: TSP AFM Cam?
Post by Numbah1 »
So it wont work in our cars? Youre the first guy to imply that
Ilikemtb999
Re: TSP AFM Cam?
Post by Ilikemtb999 »
It will not. TSP is very easy to talk to and very helpful, worth giving them a call.
kevink
Re: TSP AFM Cam?
Post by kevink »
Numbah1 wrote: Wed May 29, 2019 9:39 pm So it wont work in our cars? Youre the first guy to imply that
The L77 does not have the necessary hardware for VVT. In addition to a VVT cam, it requires a specific oil pump, cam phaser, some electrical connections, timing cover, tune, and probably more stuff I don't even know about! Is it possible to convert the L77 to VVT? Maybe, but it's not worth considering in my opinion. You are probably better off spending the money elsewhere.
Numbah1
Re: TSP AFM Cam?
Post by Numbah1 »
Lol they said none of their cams work while having active DoD, asked about vvt and they said the cam wont work anyway. I set them the link above and asked if i have the AFM feature tuned out if it would still be useable and well...
lastcall190
Re: TSP AFM Cam?
Post by lastcall190 »
Interesting sales approach.
kevink
Re: TSP AFM Cam?
Post by kevink »
TSP gave you the right advice. As stated above, that is a VVT cam. The Caprice does not have VVT, so using it in a Caprice would be asinine. Why are you so set on putting a VVT cam in a non-VVT engine? It really makes no sense at all. Like negative sense. You should google VVT to get a basic understanding of how it works. After that, it should be pretty clear why you shouldn't put a VVT cam in a non-VVT engine.
