Lucy (2011 Caprice) gets a supercharger
17mwolfe
Post by 17mwolfe » Wed Dec 25, 2019 5:16 pm
Im in the process of installing a LSA supercharger on my 2011 Caprice (Lucy) Im using as many new Gm parts as I can. They are not that much more than used one when you are buying from www.gmpartswarehouse.com. I am a GM technician and they even beat my employee prices! I have most things collected based on "Silversled"'s great write up of his LSA install. I still have a few big things to figure out like
What Intake/air cleaner to use?
What injectors to buy?
and Why does everyone seem to install LSA valve covers?
Any help/advice would be appreciated!
I plan to post pictures and prices I paid to help others
17mwolfe
Re: Lucy (2011 Caprice) gets a supercharger
Post by 17mwolfe » Wed Dec 25, 2019 5:19 pm
Lucy
17mwolfe
Post by 17mwolfe » Wed Dec 25, 2019 5:21 pm
installed the idler pulleys for the supercharger belt
17mwolfe
Post by 17mwolfe » Wed Dec 25, 2019 5:27 pm
I believe jegs was running a sale i order the fuel line from them
the supercharger had a 300 dollar core charge so it came out to a little more than $1800 it came with the actuator and lines so i didn't need to order them (looking into returning them)
Screen Shot 2019-12-25 at 11.23.20 AM.png (43.64 KiB) Viewed 392 times
Screen Shot 2019-12-25 at 11.23.03 AM.png (48.15 KiB) Viewed 392 times
Screen Shot 2019-12-25 at 11.22.42 AM.png (10.19 KiB) Viewed 392 times
Screen Shot 2019-12-25 at 11.22.12 AM.png (60.04 KiB) Viewed 392 times
17mwolfe
Post by 17mwolfe » Wed Dec 25, 2019 5:34 pm
some of the aftermarket items
im not really sure if i needed the solid isolator.But i saw most people doing it so I guess ill jump on the band wagon
Screen Shot 2019-12-25 at 11.29.38 AM.png (446.85 KiB) Viewed 391 times
Screen Shot 2019-12-25 at 11.30.15 AM.png (369.06 KiB) Viewed 391 times
Screen Shot 2019-12-25 at 11.30.55 AM.png (235.88 KiB) Viewed 391 times
Screen Shot 2019-12-25 at 11.31.28 AM.png (28.08 KiB) Viewed 391 times
17mwolfe
Post by 17mwolfe » Wed Dec 25, 2019 5:42 pm
the iat breakout harness is from summit the other harness extensions are from ebay
Screen Shot 2019-12-25 at 11.37.01 AM.png (30.86 KiB) Viewed 390 times
Screen Shot 2019-12-25 at 11.37.55 AM.png (229.04 KiB) Viewed 390 times
Screen Shot 2019-12-25 at 11.38.29 AM.png (200.72 KiB) Viewed 390 times
Screen Shot 2019-12-25 at 11.38.50 AM.png (25.19 KiB) Viewed 390 times
17mwolfe
Post by 17mwolfe » Wed Dec 25, 2019 5:43 pm
f
Screen Shot 2019-12-25 at 11.36.25 AM.png (206.95 KiB) Viewed 390 times
17mwolfe
Post by 17mwolfe » Wed Dec 25, 2019 5:56 pm
1
Screen Shot 2019-12-25 at 11.51.24 AM.png (40.88 KiB) Viewed 390 times
Post by s/c'd cav » Thu Dec 26, 2019 3:49 pm
the reason for the LSA valve covers is so the coils clear the s/c , i dont remember if they actually hit , or if its just added clearance room
17mwolfe
Post by 17mwolfe » Sat Jan 25, 2020 4:52 pm
I plan to use the unused power feed for the cylinder deactivation to power my intercooler pump relay
I also plan on running the wiring harness on top of the supercharger snout it fits so much nicer and it will keep it away from heat.
