Dyno sheet
bstoner
Re: Dyno sheet
Post by bstoner »
Ridgeppv wrote: Thu Jan 20, 2022 1:21 pm I'm going to try and go LSA next depending on the pricing. Also with the cam I have might be a good idea for a torque convertor. Pushes just a little when stopped.
That is my plan. In about 5 years, pull motor, rebuild forged lower end, and go LSA. Don't have the funds to do it now. What is your idle rpm? Can you play around with idle timing and rpm to help reduce the push?
Ridgeppv
Re: Dyno sheet
Post by Ridgeppv »
bstoner wrote: Fri Jan 21, 2022 9:53 am
I'd have to check again when I get home and the tuner played with it and got it minimized to almost no push so I'm happy with it!
Fandango
Re: Dyno sheet
Post by Fandango »
GammaFlat wrote: Thu Jan 20, 2022 2:19 pm
bstoner wrote: Wed Jan 19, 2022 12:15 pm So I went and weighed my valves today....
Used L77 Intake- 111.1g
Used L77 Exhaust- 90.5g
New LS3 Intake- 88.8g
New Manley 11661 Exhaust- 91.1g
Thanks for the valve weights. The LS7 is the one with sodium filled exhaust valves. I'll go stand in the corner now. According to "OnAllCylinders.com", the sodium filled LS7 exhaust valves are 74g. Unfortunately, they're 1.610 in diameter. LS7 intake valves are 77g but again, too big for us: 2.205. Our intake and exhaust are: 2.165 and 1.590 (same sizes as LS3).
I bet if you could find them, that LS7 exhaust valve could get the OD cut down by your favorite machinist.
AceVL
Re: Dyno sheet
Post by AceVL »
Ridgeppv wrote: Sun Jan 16, 2022 10:04 pm
JUNKYARD_JACK wrote: Sun Jan 16, 2022 1:38 pm I'm curious what the milled heads did as far as power, I had not planned on doing anything to my cylinder heads but I like the results here.
Milling the heads will raise compression just a bit and also smooth out the surface. One thing you should for sure do is get LS3 hollow valves. If you keep stock valves your tuner will not raise the RPM's over 6500, due to possible valves floating. So get the hollow valves. I wish I put in the valves because I would have had about 410 to the wheel
How much did you mill off?
South Cackalacky
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
