Catalytic Converter
Bosco
Catalytic Converter
Post by Bosco »
Anyone have an angle on a replacement for the right side cat?
Raunchtastic
Re: Catalytic Converter
Post by Raunchtastic »
Step 1. Remove old catalytic converter
Step 2. Install new catalytic converted
All jokes aside, are you talking about the passenger front cat or rear? For the front one I would think just drop the X-pipe, unbolt it from the manifold, then bolt the new one in and reinstall the X-pipe. for the rear cat, just cut it out and weld a new one in.
What happened to yours Bosco? Still within any of the federal emissions warranty limits?
Bosco
Post by Bosco »
I thought the cat on right side was bad. Was making a lot of noise but was loose. I was thinking replacement but it never caused a code. I am at 83k on the miles so my warranty is over.
Was one of the mounts bad? Or just loose at the joint?
Bosco
Post by Bosco »
Just loose at the point. My other problem is the noise that made me check it is actually coming from my trans. But the motor runs great and the trans shifts nice. My torque converter may be going south.
jackleg
Post by jackleg »
Bosco wrote:I thought the cat on right side was bad. Was making a lot of noise but was loose. I was thinking replacement but it never caused a code. I am at 83k on the miles so my warranty is over.
The cat converters should have 10 yr / 100k warranty.
2011 9C1 6.0
Flex fuel tune
Hmm, I'd check a couple of other things, namely, the accessory belt tensioner and A/C compressor and pulley. The compressor is known for taking a dump at the most inopportune time, and a failing tensioner can make quite a racket.
