Semi-Quiet exhaust to use with Kooks
Turtle Bite
Post by Turtle Bite »
I recently bought a 2011 with Kooks long tube headers and cats, and it has SLP loudmouth mufflers. They drone, and are too loud for a daily driver. This car has a Nightfury cam so 4cyl/8cyl changeover is not a concern.
I am looking for something pretty mild. I can cut and weld but would like to buy a kit to make it a relatively quick changeover. Magnaflow is my go to usually, but I am told they drone bad on a G8.
I am considering a G8 Mach Balanced CAT Back Exhaust Kit. Any opinions/ experience please share.
2011 Caprice, Night fury cam, kooks, SLP loudmouth, holden stuff, H&R, baby haulin hot rod.
lastcall190
Re: Semi-Quiet exhaust to use with Kooks
Post by lastcall190 »
Loudmouth is basically straight pipes so I can imagine how it is.
Since you can cut and weld, I would just get the Solo if you want. You will likely have to chop up some or most of the x-pipe I would imagine to salvage the cats.
G8 board probably has a bunch of feedback for the Solo systems with long tubes. I was speaking with one guy over there about his Mach Balanced system and he enjoyed it quite a bit. I went a different route, but I would see what others over there have to say. Good luck.
G8GT mufflers kept my cammed GT quiet and zero drone
for the ppv you would need to extend the tips to match the bumper
