exhaust picks
cerbomark
exhaust picks
Post by cerbomark »
what do you all recommend for a slight upgrade to the PPV mufflers to add a little more sound but not loud or done prone?
$$ conscious too.
Thanks.
2016 C1
Re: exhaust picks
solo's
cerbomark
Re: exhaust picks
Post by cerbomark »
s/c'd cav wrote: Wed Mar 20, 2019 1:35 pmsolo's
thought it sounded a little loud over the internet. ??
2016 C1
Re: exhaust picks
While I don't have a lot of miles on them, I have driven the car just about every way possible, around the neighborhood at ~30, down the highway at 70, and on an autocross course in sport mode, I don't find my exhaust to be much louder than the OEM system it replaced. I can tell when in 4-cyl mode more, but I'm not detecting any drone. Here's what I have:
Solo high flow G8 cats.
X-Force Varex exhaust.
The dual tips and stainless muffler look good, too.
Re: exhaust picks
Post by xcidmigs »
Cut out the center suitcase and replace with straight pipes.... if you don't like that then go to either bullet type mufflers or a Magnaflow X flow which is just one muffler with x pipe inside.... If your mufflers are still decent thats the best sound vs. $$$ until you start replacing everything
Re: exhaust picks
Being from NY, the flex joints and bolts attaching the mufflers are probably about done. Watch those. The upper seam on the mufflers need watching, too. One of those seams on one muffler on our ‘12 9C1 was already leaking.
Re: exhaust picks
friend of mine has solo's whole catback on his SS , and its really not as loud as either of would have thought , the J tube helps out
cerbomark
Re: exhaust picks
Post by cerbomark »
xcidmigs wrote: Wed Mar 20, 2019 6:34 pm Cut out the center suitcase and replace with straight pipes.... if you don't like that then go to either bullet type mufflers or a Magnaflow X flow which is just one muffler with x pipe inside.... If your mufflers are still decent thats the best sound vs. $$$ until you start replacing everything
What s the sound like with the center suitcase out? Is that a resonator? That sounds easy.
anyone have a vid clip on that sound? Thanks.
2016 C1
