Why just fix the leak when you can eliminate the choke points?
Posted: Wed Oct 07, 2020 2:07 pm
I’ve been listening to an exhaust leak on this car for quite a while. It is annoying, but not obnoxious so it has been easy to put off the repair. I’ll link a video of it idling for reference. I’m not sure what happened to the video sound, but it somehow picked up a bunch of extra noise. I finally got to a good stopping point on a truck project and decided it is time to give the PPV some love.
Turns out the hole is in the top of the first muffler. The shared one where the 2 sides come together. The cheapest option would be to cut it out and replace it with a couple pieces of pipe. I’ve already eliminated DOD, so the DOD drone would not be a concern if I were to go that route. But if I’m already under there hacking up the exhaust, why not eliminate some of the choke points while I’m at it?
My current plan is to build an expansion chamber to go in place of the failed muffler. I’ve read several of Vizard’s articles on using expansion chambers to build a no-loss exhaust system and have been wanting to try it. This seems like an ideal platform to try it on since we have this great area where the pup cats and muffler currently reside. I’ll join the manifolds to the expansion chamber with 3” pipe. Yes, this is overkill with the 2 1/8” outlet of the manifolds, but I’m planning ahead for headers. Speaking of the manifolds, I also plan to do some massaging at the outlet to get them up to at least 2 ¼”. Out of the expansion chamber will be 2 ½” pipe back to the factory muffler flange. I’m going to leave the factory mufflers alone for now. My wife has already voiced significant concern over making this car sound like… umm… “poop”. Which, I think, means loud.
My intent is to eliminate the exhaust leak, eliminate the 3 major restrictions on each side, while also making the exhaust no louder than it is with the current exhaust leak.
I'll update here as I go.
[media]https://open.lbry.com/@TheMidwestHack:b ... 967ergcUDY[/media]
It doesn't look like the embedded video is going to work for me. Here is a link that should: [nturl]https://open.lbry.com/@TheMidwestHack:b ... 967ergcUDY[/nturl]
Well, I can't figure out how to embed it, but either link above should take you to the video.
