So I took the measurements, Did the math and decided to buy the kit from SOLO
I spoke with the CEO and the sales guy and went with the MACH kit. The Mach shorty would have been better but I daily this car and I am really sick of noise in the cab.
Low buck exhaust. Drone at 2k
Re: Low buck exhaust. Drone at 2k
- Solo.jpg (75.81 KiB) Viewed 5624 times
Follow-up: Very pleased with the exhaust system. Sometimes I wish it was louder but every morning at 4:15am I'm glad it isn't. In conclusion, don't cut off your rear mufflers, get the Solo mufflers or go full cat back. These cars need the J pipe. Un-Driveable without it.
Good real world info here sir, this is why i ended up with the electric cutouts on mine can't find a 100% all the time solution...
at what part of the exhaust did you put the cut-outs?
I've been considering leaving the mufflers and getting rid of everything else just worried that it may get too loud.
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Cutouts go right at the pumpkin area before the OEM mufflers so you get either stock type sound or Open
