Kooks 2014 SS system install on 2012 9c1
Here is a few pics. The parts are tagged from Kooks Right, Left and top. They are wrong! Maybe becaus it's a caprice but I don't an SS to varify. The header fit is fantastic and clears the oil cooler. System is tucked up tight and the only mods seem to be the factory muffler connection. I am working on it now and will post updates when I'm done.
- 1432324444379.jpg (981.75 KiB) Viewed 21027 times
- 20150522_115608.jpg (850.57 KiB) Viewed 21027 times
Dave
Chatsworth Ca
30 model A pickup QMP 383
71 GMC suburban 4X4
Chatsworth Ca
71 GMC suburban 4X4
Re: Kooks 2014 SS system install on 2012 9c1
Very interested in the details. Thanks.
I guess you took the day off!
Bob Dannelley
Yep. Weather was good for working outside.
For the details.
Did not have to extend the pipes. I did however need to make a pipe from the so called factory connection to the factory muffler. The mounting lugs on the cats needed to be bent down a 1/2 " to suck the system up tight. The driver side pipes run about 1/16 from the frame. The driver o2 sensor wires need to be extended 4". All in all about 5 hours on a rack and a few brews.
My car came from Wisconsin and is a bit rusty for a 2012. I would recommend soaking the bolts with wd40 or the like before you start. One of the 15mm cat nuts rounded off and I had to hammer a cheap 12 point 9/16 to get it loose.
The sound is a bit louder than stock with that little header tic as the exhaust pulse hits the tube.
I'll take a video and post it up in a bit.
For the details.
- 20150522_164552.jpg (618.92 KiB) Viewed 21018 times
- 20150522_164527.jpg (764.32 KiB) Viewed 21018 times
Dave
Chatsworth Ca
71 GMC suburban 4X4
Chatsworth Ca
71 GMC suburban 4X4
https://youtu.be/gqtcJF2OR5I" onclick="window.open(this.href);return false;
Dave
Chatsworth Ca
71 GMC suburban 4X4
Chatsworth Ca
71 GMC suburban 4X4
I'm considering the kooks headers vs Xforce and others. Can you tell me what the center to center is on the header outlets? It would be a big help.
1968 K10 short wheel base
2009 Silverado 1500
2013 9C1 - PBM - Sold
2019 Silverado 1500 - LTZ 6.2
2009 Silverado 1500
Might you have any pictures of this fabbed pipe? Or at least a better description? Thanks.orgdnr wrote:Yep. Weather was good for working outside.
For the details.
Did not have to extend the pipes. I did however need to make a pipe from the so called factory connection to the factory muffler. <SNIP>
Bueler, Bueler? Inquiring minds want to know.CrashTestDummy wrote:Might you have any pictures of this fabbed pipe? Or at least a better description? Thanks.orgdnr wrote:Yep. Weather was good for working outside.
For the details.
Sorry about that. Not the prettiest welds but flux core mig is what it is.
- 20160212_113945.jpg (705.1 KiB) Viewed 20567 times
- 20160212_113951.jpg (682.96 KiB) Viewed 20567 times
Dave
Chatsworth Ca
71 GMC suburban 4X4
Chatsworth Ca
71 GMC suburban 4X4
Cool. So it's like a 1-1.5" extension? One could probably do that with band clamps, right?
