Burnouts?
Arcticolds442
Re: Burnouts?
Post by Arcticolds442 » Fri Dec 09, 2016 5:04 pm
Thanks for the tip Silversled. I hadn't seen that table before. Maxing these values out has reduced the life of my rear tires significantly!
2012 9C1 DD - stock for now
'72 Olds 4-4-2
'65 AMC Rambler - LQ4/T56 work in progress
"No Bucks Given" '84 VetteKart
'65 Cutlass
ryanswit
Re: Burnouts?
Post by ryanswit » Wed Jan 25, 2017 1:59 pm
Speaking of burnouts, has anyone found a line lock that fits a 2012?
Jeff M
Re: Burnouts?
Post by Jeff M » Sun Mar 12, 2017 2:15 am
Silversled wrote:As 9C1fanatic stated, there is a significant amount of Torque Management placed on our cars. One such layer of managment is the "Braked Torque Limit" table which limits the amount of torque the engine is allowed to make for a given Throttle Position and Manifold Pressure (engine load). So when the car sees the brake pedal depressed like when starting or doing a burnout, this table is envoked.
Shown below is the Braked Torque Limit table on my 2014 PPV's stock tune. Note that straight from GM, the car will not make more than 169 Ft-lbs of torque regardless of load or throttle position.
I just changed all the numbers to the max number permitted by the ECU.
There is so much left on the table with the factory tune on these cars, at least on my 2014. Just a straight tune to turn off the Torque Management and tweaking the PE (throttle responsiveness, etc) alone without changing the fuel or spark maps completely wakes up this car!
What tuning software is this? HPTuners?
Silversled
Re: Burnouts?
Post by Silversled » Sun Mar 12, 2017 3:25 am
Yes
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
camrat68
Re: Burnouts?
Post by camrat68 » Sat Jun 24, 2017 6:23 pm
Silversled-Which version of HPTuners did you get? It doesn't show that they support anything for the PPV's much less my 2012 PPV.
Jim
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
2013 Black/White 9C1--NADACOP-Stock. For now......
Silversled
Re: Burnouts?
Post by Silversled » Sat Jun 24, 2017 9:02 pm
camrat68 wrote:Silversled-Which version of HPTuners did you get? It doesn't show that they support anything for the PPV's much less my 2012 PPV.
Jim
The reason that they don't list it is because it is too rare to list. I didn't have versions before version 3.0 but any of the 3.0 versions support our cars.
2016 AMG C63
camrat68
Re: Burnouts?
Post by camrat68 » Sun Jun 25, 2017 7:23 pm
Good to know!
Thank you,
Jim
Jim Chesnutt
