Motor Mounts: Holden Substitute?
B4CU
Post by B4CU »
My motor mounts need to be replaced. Before I pulled the trigger on these https://www.gmpartsdirect.com/oem-parts ... LWZsZXg%3D does anyone know of a Holden part number equivalent part that is possibly better/cheaper?
I found these https://www.sparesbox.com.au/part/kelpr ... nt-mt9885a not sure if it is worth the hassle to see if they are the same.
2013 White 9C1 Caprice
Re: Motor Mounts: Holden Substitute?
The same GM part is $93 at Rock Auto, so I'd say you're probably not going to find it any cheaper as an OE part. When you run an order on GMPD, the final cost will probably be about the same as RA.
https://www.rockauto.com/en/moreinfo.ph ... 66&jsn=911" onclick="window.open(this.href);return false;
RA discount code - 5F8633D34235E1
GMPD is $183/pr for my ZIP 30115
RA is $186/pr for my ZIP (with 5% discount code)
The part in Australia--even if they will sell & ship to US, what will final cost be to get them here--and will quality be same as or better than GM's part?
B4CU
Post by B4CU »
Navy Lifer wrote:The same GM part is $93 at Rock Auto, so I'd say you're probably not going to find it any cheaper as an OE part. When you run an order on GMPD, the final cost will probably be about the same as RA.
That is basically the conclusion that I came to. Thanks Bill!
RM96
Post by RM96 »
If you're looking for an upgrade, check these out from Karo @ holdenpartsusa
https://holdenpartsusa.com/collections/ ... -mount-set" onclick="window.open(this.href);return false;
B4CU
Post by B4CU »
[quote="RM96"]If you're looking for an upgrade, check these out from Karo @ holdenpartsusa
That is ridiculous and amazing.
ive got the ones from HOLDEN PARST USA , love um !!!
also dont have to worry about any failures
