Leaking rear main seal
mikem85
Post by mikem85 »
Hi guys. I just got my '14 PPV the day after Christmas and brought it home. Took it on a road trip to Kansas City and when I got back realized the thing has a pretty considerable oil leak. There is oil all over the bottom of the back of the engine and all over the transmission. I felt around the oil pressure sensor to see if it was leaking, it's dry so I'm assuming it's the rear main seal. Any advice for changing it? How easy or difficult is it to drop the transmission in these cars?
Re: Leaking rear main seal
its kinda a bitch , the trans is big and heavy
id recommend cleaning the area best you can , top to bottom , front to back , before doing any work to actually fix anything
Can't help with the trans drop, but I'll note that the oil cooler mounts off a boss above the oil filter. Our '10 Tahoe had a leak around a plug on the back of the cooler mount. Easy enough to fix, but there was oil staining on the back of the engine, too. Not sure what the Caprice oil cooler configuration looks like, but you might also check around for a similar plug. Here's a picture of the Tahoe part:
The leaking plug is on the lower right side of that aluminum block with the tubing coming out of it in the photo. The oil filter is to the lower left corner, and the transmission is off the lower right corner.
mikem85
Post by mikem85 »
So I got the car to a mechanic, he put some dye in the oil to find the leak and apparently it isn't the RMS, it's coming from up high on the engine and it's about impossible to tell where from. Is there anything closer to the top of the engine that would leak that bad? Again I checked around the oil pressure sensor and it was dry. Would the intake gasket leak oil if it was bad? Maybe even a valve cover gasket? Anything else up there that I can't think of? He said he would have to pull the intake to see where the leak is coming from. Where are the oil cooler and lines on this thing? Any help is appreciated. Thanks!!
Post by Pursuit »
The oil cooler is ahead of and slightly above your oil filter. It is kind of diamond shaped, sandwiched aluminum block. It circulates engine coolant through it, to cool the oil. There are no oil lines leaving it. But, they have been known to possibly fail.
mikem85
Post by mikem85 »
Could a head gasket cause this amount of oil leakage? Speculating with a flashlight it looks dry but I'll check it again after I get the car back.
mikem85
Post by mikem85 »
Also the cam and lifters have likely been replaced on this engine based off the number of hours on it. Could that DOD manifold leak oil under the pressure sensor? Like if whomever did the work jacked up that gasket somehow?
up high is either going to be valve cover gaskets , valley cover , or the oil pressure sensor
mikem85
Post by mikem85 »
I figured it out!! There's a steady leak at the very top middle under the valley cover. Was pretty easy to feel for so I'm gonna ask for my money back for the dye test since the mechanic was (IMO) too lazy to find it. Does anyone here have a good reference for torque settings on the intake and valley cover bolts?
mikem85 wrote: Thu Jan 09, 2020 1:33 pm Also the cam and lifters have likely been replaced on this engine based off the number of hours on it. Could that DOD manifold leak oil under the pressure sensor? Like if whomever did the work jacked up that gasket somehow?
I see you figured it out, but never assume the lifters fail on high mileage/hours vehicles. Our Caprice got lifters/cam replaced at 23k miles, but our ‘10 Tahoe PPV is still running on OEM parts. Just a comment here.
