Electrical?? Issues??
GeminiCoyote
Post by GeminiCoyote »
2011 L77 6l80... just bought very cheap. It was great before they took out their electronics. Now trans only has 3 gears.. acts like it's in limp mode. Very weak throttle but runs like a clock. Aslo the performance button and shift button are dead! Any suggestions...
2011 Chevrolet Caprice PPV 6.0 6l80. White
"THE TWINS"
1976 VEGA WAGON GT 454 TH400.
Re: Electrical?? Issues??
make sure those buttons are plugged in , and go through all areas they had wires in , console area and pass side under dash to start
GeminiCoyote
I will start there thanks
"THE TWINS"
other wise next place would be to scan the car for codes , and start from the code
the abs , bcm and other codes will need a special scanner , not just the normal vatozone code reader that looks at the pcm
GeminiCoyote
More simple fix than I hoped!! TC fuse was missin!!
"THE TWINS"
