Driveshaft Center Carrier Bearing
Posted: Thu Jul 30, 2020 9:48 pm
Found an interesting parts situation today when discussing the center carrier bearing on our cars.
I had come to the conclusion that since our center carrier bearing was discontinued all we could do is a new driveshaft if it goes bad.
Someone mentioned "Does the G8 fit? " I thought surely if ours is discontinued the G8 one is also!
Well.
No. The one that fits all the G8's also fits the SS's and the V6 PPV's. So the V8 PPV's got a special part??
I doubt it but I wonder. Further looking found the WN PPV's had a separate part number and it listed coverage back to the WM Caprices! So the conclusion is we still can get the part. And that last link I will put is a cheaper non GM version of the G8 part that I believe should be all the same for all the G8, SS and PPV's now that I see all the overlap in these listings.
Anyway here are the relevant parts:
92189411 - Driveshaft Center Support Bearing G8/SS/V6 PPV
92254456 - Driveshaft Center Support Bearing 11-13 V8 PPV - DISCONTINUED
92292281 - Driveshaft Center Support Bearing All Year PPV's
Cheaper Version of the Carrier Bearing at Driveshatparts.com
Well.
