What stall with E1840P Cam for Daily driver?
Turbopowered68
Post by Turbopowered68 »
2014 Caprice 6.0 6L80 with a tune.
Bone stock 6.0 besides Cam and springs
Cam is E1840P, Springs are Pac1218
Problem = Engine is pushing on the OE converter at idle.
I am considering the ZL1 converter GM (24242552)
I don't mind leaving some performance on table just looking to NOT push on the converter when my fat foot isn't on the throttle.
Thanks For your help.
2014 Caprice V8
1986 GN
1968 Chevelle
Re: What stall with E1840P Cam for Daily driver?
your best bet is to talk to a couple companies that do converters , and get their recommendations
also a good tuner can eliminate some if not alot of the surge you are getting
AceVL
Post by AceVL »
Turbopowered68 wrote: Tue Jan 12, 2021 7:02 am 2014 Caprice 6.0 6L80 with a tune.
The 1840P is the 228/230 .585 112 right?
I ask because people are running even larger cams (TSP LS Stage 1 and BTR STAGE1) and not having huge surging problems. A converter will always help putting the power down, but Could it be a tune issue? Or too high idle?
I’m planning on getting a cam that’s around that size and don’t want to do a converter, so I want to make sure it won’t be too much since it’s a little larger than the 1840p.
South Cackalacky
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
