Grinding from rear passenger side
Dbtheemcee
Post by Dbtheemcee »
I have a 2012 caprice V6. It started when I would accelerate from a stop I would get a slight thumping sound from the rear end. That quickly went from thumps to grinding. Now the car won’t accelerate over 7 mph and has significant power loss. If I try to go above that the brakes engage and slow me back down. I bought a replacement rear end from a caprice with 2000 miles on it that crashed in the front. The shop replaced the rear end but the issue is still present exactly how it was prior. I jacked it in the air and removed the rear tires and put the car into drive. The driver side rotated fine but the passenger side was choppy, like stuttering.
I’m at a loss now for what it could be. When I started the car to move it to be towed to the shop, the dash reported an stabiltrack fault. But when I restarted the car it was gone. Other than that no lights or warnings have appeared on the dash.
Re: Grinding from rear passenger side
likely the parking brake
shawnjon82
Post by shawnjon82 »
Parking brake pad has probably come apart and is stuck in the brake drum. It happened to me and was a easy fix
Dbtheemcee
If it’s as simple as a parking brake, I will be thrilled. Also I’m glad the car lot I bought the car from covered the cost to swap the rear ends.
Dbtheemcee
So it wasn’t the parking brake. Does anyone have any other ideas?
wheel bearing
caliper not releasing (check/compare pad wear with other side) - slide pin{s} seized, piston stuck, defective brake hose keeping brake applied
Dbtheemcee
Well it seems like the car is in a limp mode. The dash doesn’t tell me that but I tried to move it today and got a CEL. The codes came back P0700 and P0797. I still believe that there is grinding coming from my passenger brake area but it appears more is going on.
those codes are related to the transmission
Dbtheemcee
s/c'd cav wrote: Fri Jul 16, 2021 5:22 pm those codes are related to the transmission
Yeah I’m trying to figure out how this all relates to my issue
Dbtheemcee wrote: Fri Jul 16, 2021 6:05 pm
have you had some stand or hang out the rear pass door to verify the noise is coming from the RR tire area ? and not the center around the trans ?
