BMR trailing arms
BossAwesome
BMR trailing arms
Post by BossAwesome »
http://m.bmrsuspension.com/?page=produc ... CEAFB8C986" onclick="window.open(this.href);return false;
Does anyone know if these work for our Caprices? I'm looking for a way to reduce wheel hopping and it sounds like these help alot for the G8 guys
2012 Caprice PPV 6.0
Re: BMR trailing arms
Post by xcidmigs »
I've installed the OEM camaro rear lower 1LE arm onto my 2011 caprice, zero issues fittin or driving on it so i have to assume that the BMR part will fit also. I did buy a couple things from them like the center tunnel brace which they didn't know but did fit the caprice and also the rear suspension mount poly inserts which do not fit at all. I dealt with them directly and was able to return the mounts even though they were opened and partially installed without any hassel. I think they just have not seen one of these to fully answer what will work or not.
