Brake Fluid
Brake Fluid
Interesting discussion: https://bobistheoilguy.com/forums/ubbth ... /2566812/1" onclick="window.open(this.href);return false;
Comments, personal experience, thoughts welcome!
GM - 16oz DOT4 spec: http://www.gmpartsdirect.com/oe-gm/19299570" onclick="window.open(this.href);return false;
  • Can be mixed with any other well-known brake fluids with same specifications
    Chemically stable
    Contains additives guaranteeing best lubricating properties
    Exceeds international specifications SAE J 1703, ISO 4925; as well as the U.S. FMVSS 116 DOT-4
    OEM fluid filled at factory for: Pontiac GTO, Pontiac G8, and Saturn Astra
From 2017 Chevy SS Owner's Manual (PG 358)
Hydraulic Brake/Clutch System DOT 4 Hydraulic Brake Fluid (GM Part No. 19299570)
StopTech "White Paper" on Brake Fluid
http://www.stoptech.com/technical-suppo ... rake-fluid" onclick="window.open(this.href);return false;
Re: Brake Fluid - other brands - DOT4
https://shop.advanceautoparts.com/p/pen ... lsrc=aw.ds" onclick="window.open(this.href);return false;
https://www.walmart.com/ip/Prestone-DOT ... 3=&veh=sem" onclick="window.open(this.href);return false;
https://shop.advanceautoparts.com/p/val ... lsrc=aw.ds" onclick="window.open(this.href);return false;
Here's another I ran across: https://www.bremboparts.com/america/en/ ... rake-fluid" onclick="window.open(this.href);return false;
