Brembo front calipers using 345mm PPV rotors
Re: Brembo front calipers using 345mm PPV rotors
Navy Lifer wrote: Sun Jun 23, 2019 9:43 am
CrashTestDummy wrote: Fri Jun 21, 2019 1:11 pm I called GM Parts Direct and asked about this kit, and the guy on the phone said the P/N was discontinued, with no update, and they have zero kits in stock and are finding no inventory.
The list of calipers for 2016-2019 'Camaros' is dizzying, and is all over the place for prices. Does anyone know the P/N for just the calipers that replace those in this kit?
Gene, the 5th post in this thread spells out what PN's work. The Camaro PN's are listed in the G8 Forum link, but prices are higher for the Chevy logo calipers.
viewtopic.php?f=18&t=2778#p22066
Thanks, Bill. I think I finally figured it all out and have a pair of calipers on their way. I ordered one via Amazon, but the other was actually cheaper from GMPartsDirect, by nearly $100. I figured new ones are better than the used CTS-V calipers I have that will require cleaning and swapping the crossover tube and bleeder screws over.
Primary reason for the swap is the reduction in unsprung weight. Hopefully the pedal feel will be nice, too. We'll see.
EDIT: Update - the Caliper I ordered via Amazon is already here. It's pretty! :-)
The other caliper also hit the door. That order included a replacement set of bolts. Now on to the hoses. Goodridge, or Techna-fit, Goodridge, or Techna-fit? Decisions, decisions.....
Fudgehog wrote: Mon Jun 24, 2019 4:18 pm I did apply new blue loctite as well and torqued to 30ft lbs and then some.
The torque spec on these bolts is 30 lb-ft + (plus) 90 degrees additional bolt rotation.
Put a mark on the knuckle and bolt head 90 degrees apart so that tightening moves the mark on the bolt head toward the mark on the knuckle--depending on access & tools, using an impact tool may be necessary/best way to reach the prescribed torque.
CrashTestDummy wrote: Wed Jul 03, 2019 8:53 am The other caliper also hit the door. That order included a replacement set of bolts. Now on to the hoses. Goodridge, or Techna-fit, Goodridge, or Techna-fit? Decisions, decisions.....
Gene, I have a Techna-Fit 4500 kit available, with brackets, already modified, $120 delivered--I only ask that you send me the removed front brackets (cut off the hoses).
That will be perfect! Thank you.
BigMike0147
Post by BigMike0147 »
Bill, you don't happen to have one more set available, do you? I was thinking about ordering a set of the black brembos.
BigMike0147 wrote: Sun Aug 18, 2019 11:42 pm Bill, you don't happen to have one more set available, do you? I was thinking about ordering a set of the black brembos.
Sorry I just saw this.....I don't get notifications, not sure this Forum even offers the feature (and I'm considered "admin staff")!?!
I do have a hose kit, or you can order direct from Techna-Fit. It just depends on whether you want to modify the brackets yourself, or have me send some already modified.
Navy Lifer wrote: Fri Sep 06, 2019 7:27 pm
i got notification of your bill , so there is something there that kinda works , lol
BigMike0147
Thanks Bill. I emailed you at the email I. Your signature.
s/c'd cav wrote: Fri Sep 06, 2019 7:35 pmi got notification of your bill , so there is something there that kinda works , lol
Just took a look at notification settings and changed a few things....we'll see if that makes a difference.
