2014 PPV front end noise
VintageIron41
Post by VintageIron41 » Fri Jan 11, 2019 7:16 pm
Hello and thanks for taking time to read this.
Just received my 2014 Caprice ( GovDeals purchase), a quick turn around the block and backing it into the driveway reveals a substantial front suspension noise, obviously it will get checked out over all, but, what might be the most likely cause? 122k miles from South Carolina.
Thank you!
SBRMD
Re: 2014 PPV front end noise
Post by SBRMD » Fri Jan 11, 2019 8:10 pm
I've had to replace the stabilizer links twice in my car, apparently that's a weak spot....they definitely make noises when bad.
Steve Robin
Minneapolis, MN
'11 PPV 9C3 Phantom Black Mettalic
VintageIron41
Post by VintageIron41 » Sat Jan 12, 2019 8:16 am
Thank you Sir, those do go away, it will get a thorough going over soon, this is my first PPV, so am looking to learn where the weak spots are.
Thanks again for replying!
sardillim
Post by sardillim » Sun Jan 13, 2019 12:59 am
same with me links and strut mounts i would use GM parts i had one Moog strut mount come apart after 4 months
Post by s/c'd cav » Sun Jan 13, 2019 9:29 am
do not use the OE mounts , they are junk
use these - https://holdenpartsusa.com/collections/ ... -g8-ppv-ss
Post by CrashTestDummy » Sun Jan 13, 2019 11:44 pm
Indeed. OEM strut mounts are a bit soft, and tend to settle with time, resulting in a rattle when the suspension moves up and down. I'd usually recommend OEM replacements, but not in this instance. Whiteline is the way to go.
2010 Tahoe PPV (her car)
VintageIron41
Post by VintageIron41 » Thu Jan 17, 2019 6:42 pm
Thank you for your informative replys!
