Control Arm Torque
lastcall190
Control Arm Torque
Post by lastcall190 » Mon Apr 15, 2019 1:38 pm
I think I got the correct control arm torque values (30 + 60* at the ball joint end, 30 + 120* at the bushing end), but from what I gather, the bushing side is to be torqued with the wheels on the ground. Not that big a deal because 30ft-lbs is not much. However the additional turns, I mean... are they serious? I got what I believe is damn near 120* after some clever extensions and my universal joint, but does anyone have any hints (still have passenger side to do, storm ran me back inside)? Should I have rested the knuckle on a stack of wood so that I could get away with the tire not being present?
Thanks all for the suggestions. Good news is that the stock pieces had some seriously loose ball joint ends, so if nothing else, maybe that will help tighten things up.
!DOD : LS9 Cam : Pat G : Magnaflow : VCM
168k and going strong
Re: Control Arm Torque
Post by CrashTestDummy » Mon Apr 15, 2019 2:01 pm
I can't address the additional amount of turning after reaching the desired torque value, but you do really want to have the suspension resting on the the wheels and supporting the weight of the car when torquing those bolts. Supporting the corner with a jack under the ball joint doesn't set the suspension it stock ride height. You might be able to create some alignment hub stands, or similar items, so you can easily get into the wheel wells, but yeah, you're going to want to have the car's weight on the suspension so you're not back doing that work again in a few months.
2010 Tahoe PPV (her car)
lastcall190
Post by lastcall190 » Mon Apr 15, 2019 2:13 pm
Fair enough, can't really complain I mean the parts came off reasonably easy which was already a nice bonus. I'll just get my extension and u-joints working overtime and make it happen. With the wheel liner and under pan removed, the front LCA bolt is easy to get from the engine bay, surprisingly enough. 120* adds up when you can do about 30 at a time :lol:
What I did was lowered the car onto stacked 2x10s... the driver side was on the wood and passenger side was ~3" lower on the ground. I jumped up and down on the front radiator support (With my hands pushing not literally jumping...) to get the car to settle in a little before final torque. After doing it I realized that it was a pointless endeavor and should have just put the whole damn thing on the ground again. Ah well, for the other side I'll just drop the whole thing to the ground or just get more stacked wood to keep it uniform. And if that was wrong, then I'll get more bolts and do it all again.
Thanks for the reply!
119C3NJ
Post by 119C3NJ » Mon Apr 15, 2019 8:14 pm
are you changing the bolts out and nuts? or trying to reuse original?
1995 MG5 Yukon GT Black
1972 8.2L C10 LWB for sale
lastcall190
Post by lastcall190 » Tue Apr 23, 2019 12:34 am
Anyone have any suggestions for a stubborn ball joint end? 3 out of the 4 came out with only a few taps of the hammer. This 4th one is going to drive me insane. I have tried heat, PB Blaster applied over several days, threading on a nut and trying to just flat out spin the stud, applying some pressure with some hits to the knuckle, putting a jack straight under the stud and jacking up (whole car ended up being supported) then hitting the knuckle and at this point the stud has taken such a beating that it is starting to bend. Any tools, hints, tips or tricks? I thought about a regular ball joint press but cant see how it would work since the joint is integrated to the arm and isnt removable. Foolishly I expected the last one to go as smooth as the others. Oh well. Thanks all.
