At my wits end with ABS issue!
johnpz2721
Post by johnpz2721 »
I have replaced everything bearings sensors harnesses light is still on what is next to replace still have codes c0045 and now have c0050
Should I replace the abs module next ??
Also is a 2014 module compatible with a 2012
Thanks for all the help
Re: At my wits end with ABS issue!
have you checked the wiring from the sensor all the way to the module ?
and no 12 and 14 are way different , the 14 module is a 1 year only part # , and shared with the 14 SS sedan
11-13 are a front and rear system , and the 14-17's are a cross system , 1 front and 1 rear are on the same master cylinder circuit
johnpz2721
Where do I begin to check does anyone know where I can find a diagram?
ask steve , user id is smwalker
he is pretty good with getting diagrams
great info !
thank you steve !!
johnpz2721
Thank yo so much Steve
#802PalmBeach
Post by #802PalmBeach »
Going through the same exact thing what did it end up being??
'12 Caprice PPV 6.0 L77
30 to 70 MPH in 4.0 seconds so far
'02 Silverado 5.3 L59
8.2 @ 86 (1/8 mile)
YouTube channel
Cdd0789
Post by Cdd0789 »
Has anyone figured this out? I'm having the same problem. I've replaced both rear wheel speed sensors and 1 hub bearing (that I don't think was bad). The problem started out as abs light on intermittently but now is constant. I suspect its a wiring problem but I haven't traced the wires from the back to the abs module. I was hoping someone had repaired this already and could tell me where the problem in the wiring most likely is.
