Tried to swap the 2 things calipers and rotors
They don’t seem to fit it’s actually locked up
What am I missing ??
2017 Camaro Brembos don’t fit ?? On my 2012
Re: 2017 Camaro Brembos don’t fit ?? On my 2012
Only the calipers & pads from the 2016 & newer Camaro are required--you must use the stock Zeta/PPV 345mm rotors (2011-2017), which have the correct hat height/rotor offset for this upgrade.
The Camaro rotors are also 345mm but are made to fit the Alpha chassis (16 & newer Camaro)--hat height is correct for Alpha, not Zeta.
This is addressed pretty clearly in other threads discussing this mod. Info here: viewtopic.php?f=18&t=2778
