Page 3 of 3
Re: Spongy Pedal after Brembo update
Posted: Tue Oct 29, 2019 10:10 pm
by Navy Lifer
There you go--that's the Gen6 Camaro caliper for 345mm rotor--definitely has a bleeder on the inboard side of the caliper body.
Posted: Tue Oct 29, 2019 10:15 pm
by johnpz2721
I wish that was the case but there is no bleeder !
I am going to try the pressure bleeding at a freinds shop i know there is air in the system
I looked at gen6 calipers they are completely different than these ?
Posted: Tue Oct 29, 2019 11:33 pm
by Navy Lifer
There MUST be a bleeder on the inboard side of that caliper - get that camera up inside the wheel opening and show us!
https://www.rockauto.com/en/moreinfo.ph ... 78&jsn=458
Scroll through the 4 pictures in the link (same photo source I posted earlier) - that's the Cardone caliper you reference, and it clearly shows 2 bleed valves, one inside and one outside.
Posted: Wed Nov 06, 2019 8:25 pm
by johnpz2721
No inside bleeder !!
Posted: Thu Nov 07, 2019 9:59 am
by Navy Lifer
Something is hinky, or I haven't been paying attention.....still believe there needs to be an inboard bleeder.
Is the photo showing top or bottom?
Is there a hex plug in the inboard upper position?
The reference photo from Rock Auto (Cardone reman caliper) shows a bleeder on both sides.
Did you buy these calipers new?
Is the upper inboard position blank?
If there is a removable plug on the inboard upper, remove it and see if a bleeder will fit, or if fluid comes out.
13579453 or equivalent & cap 13579454
13579453 shown to fit 13-19 Camaro, Cadillac (Alpha) w/Brembos (front)
More references:
https://www.rockauto.com/en/moreinfo.ph ... 98&jsn=584 (scroll through illustrations)
application illustrations showing bleeder - yes, a little confusing since only one is shown, same atrwork
Cadillac
https://www.gmpartsdirect.com/oem-parts ... 55/?c=bT0x
Camaro
https://www.gmpartsdirect.com/oem-parts ... r-84089059
Posted: Thu Nov 07, 2019 10:02 am
by Navy Lifer
The first photo you posted is right side of the car, showing outer bleed port in correct (upper) position, and the second photo, while not a really clear view, does look like there is a valve with rubber cap. This would be the right side caliper viewed from inboard, looking upward.
Is this correct?
