2014-2017 Replace Rear Wheel Bearings
rcg530
Post by rcg530 »
One the last large projects for my 2014 Caprice is to refresh the suspension components front and rear (shocks/struts/bushings/swar bar endlinks/etc). I've already replaced the front wheel hub assemblies (very easy to accomplish), but I'm thinking I should replace the rear wheel bearings as well. Of course that task involves a lot more work than the front bearings.
I've been searching for a thread on this site or info / video showing the replacement of the 14-17 Caprice or 14-17 SS Sedan rear wheel bearings, and so far I haven't found any. I've only found the service manual info.
I'm curious to find out from someone who has performed these tasks just how difficult it is to press out the rear hubs from the bearings and the bearings from the rear knuckles?
I don't currently have a hydraulic shop press so getting those items in/out safely is my main concern.
Thanks!
Sanford
Re: 2014-2017 Replace Rear Wheel Bearings
Post by Sanford »
I have never pressed a hub and bearing out of a Caprice. I have pressed more than my share of bearings and hubs apart on FWD’s. I don’t think you are going to perform the task without a hydraulic press. I maybe wrong, which won’t be the first time.
David
rcg530
Post by rcg530 »
I'm getting ready to replace the rear wheel bearing in my 2014 Caprice.
I'm trying to make sure I have all of the correct parts. The rear wheel drive shaft retaining nut washer (number 1 in this picture) is something I cannot find the part number for in any of the online parts sites nor in the service manuals I've been using.
Does anyone have the ability to lookup what the part number is for #1 in this picture?
rcg530 wrote: Tue Aug 17, 2021 2:15 am I'm getting ready to replace the rear wheel bearing in my 2014 Caprice.
it comes up NS=not serviced , the attached diagram is the only 1 the washer shows up in , and i checked the older caprices and the newer SS's
axle washer.jpg (242.02 KiB) Viewed 5970 times
rcg530
Post by rcg530 »
s/c'd cav wrote: Tue Aug 17, 2021 11:27 am
It's looking like I will have to reuse the original washers instead of using a new ones at this point.
that is what i would do , typically washers do not go bad
rcg530
Post by rcg530 »
I found there was not a separate washer as the parts diagram implies. The new axle nut itself comes with a washer attached.
rcg530 wrote: Wed Aug 25, 2021 2:44 am I found there was not a separate washer as the parts diagram implies. The new axle nut itself comes with a washer attached.
that is what i thought
did everything else go ok ?
rcg530
Post by rcg530 »
s/c'd cav wrote: Wed Aug 25, 2021 3:16 am did everything else go ok ?
Yes, everything else went ok. Trying to film it and do it was a bit challenging. I might get better video from the left rear since I now know what to expect. I'm giving my old body a day to rest before I tackle the left rear.
rcg530 wrote: Wed Aug 25, 2021 10:24 am
that is good ! oddly enough the 2nd time doing the job always goes a bit easier , lol
