Hard to find rear rotors Brembo
Car54
Post by Car54 »
If anyone is looking for Brembo rear rotors… go to RA. I found them by using 2012-18 Camaro as the vehicle of choice.
Re: Hard to find rear rotors Brembo
Are you sure those will fit? I used Chevy SS rear rotors, fit perfectly except having to trim the dust shield as usual. This was along with a set of 2015 Camaro Brembo calipers.
https://www.rockauto.com/en/catalog/che ... rotor,1896
camaro rear rotors , you will loose the parking brake
you need 15-17 SS sedan rear rotors
Car54
Post by Car54 »
Ya see that’s why I should of checked here. Was told that the rotors off the camaro’s were EXACTLY the same. George Carlinism’s ensuing!!!
Car54 wrote: Mon Jan 17, 2022 3:57 pm Ya see that’s why I should of checked here. Was told that the rotors off the camaro’s were EXACTLY the same. George Carlinism’s ensuing!!!
front rotors yes , rear no
Car54
Post by Car54 »
Mooseman wrote: Mon Jan 17, 2022 9:33 am Are you sure those will fit? I used Chevy SS rear rotors, fit perfectly except having to trim the dust shield as usual. This was along with a set of 2015 Camaro Brembo calipers.
Mooseman you referring to the ACDelco rotors, I’m at a loss here. If they are the ACDelco’s does it matter which ones? See 2 choices.
Appreciate the help here, gonna have to send back the wrong ones I’m getting here by the end of the week.
impalaplt
Post by impalaplt »
Don't the Chevy SS Rotors FRONT and REAR work for the Brembo Conversion????
impalaplt wrote: Tue Jan 18, 2022 2:33 am Don't the Chevy SS Rotors FRONT and REAR work for the Brembo Conversion????
yes
Car54
Post by Car54 »
The problem is that the rear rotors ACDelco ones for the 2015 Ss’s are out of stock everywhere.
2014’s are available, can we use those for the Brembo upgrade???
Car54
Post by Car54 »
