SS Sedan Springs under the 2011 Caprice PPV
Re: SS Sedan Springs under the 2011 Caprice PPV
Post by Pursuit » Tue Sep 13, 2016 3:29 pm
The different part numbers changing from year to year probably changed due to type of rear sway bar being used and also magnetic ride control being introduced. I went with the 2014 springs as they were the closest to my platform.
Regards,
Sanford
Post by Sanford » Sun Apr 09, 2017 1:58 am
I swapped some low mileage stock 2013 Caprice rear strut/spring assemblies with the factory 2011 Caprice rear strut/spring assemblies and it made a 100% improvement it ride quality. I read that the 2011 rear struts had some pretty strong valving and GM changed to some with softer valving in the 2012/2013's. My car is a semi daily driver, so I try prefer to keep the suspension as stock as possible. I can remember when the local PD added several Caprices to their fleet and I would be following beside or behind them and it looked like the rear suspension did not budge any when they drove down some of the bumpier streets in town. Now the car at least feels like the rear suspension compresses a little when the car goes over a small dip in the road. I have a 80 Corvette with the gymkhana suspension option and I believe it was a smoother ride than the Caprice until rear strut swap.
David
jackleg
Post by jackleg » Thu Apr 13, 2017 5:17 pm
There may not be a choice NOT to swap over to the SS springs- the Caprice springs show "Discontinued"
2011 9C1 6.0
Flex fuel tune
Post by CrashTestDummy » Thu Apr 13, 2017 7:08 pm
There's still rear springs available, and I'd see no reason why you can't use 2016 springs for the front.
2010 Tahoe PPV (her car)
jackleg
Post by jackleg » Fri Apr 14, 2017 2:27 pm
CrashTestDummy wrote:There's still rear springs available, and I'd see no reason why you can't use 2016 springs for the front.
Well that's good to know
I'm replacing the struts and was planning on reusing the OEM springs. The rear is done, I used the Monroe replacement for the back - they're stamped "made in Australia" and came with the lower spring rubber.
Was making plans to work on the front and the springs have lost most of the black coating and are all rusted up.
2011 9C1 6.0
Flex fuel tune
Hzgray
Post by Hzgray » Fri Apr 21, 2017 7:08 pm
I am thinking about installing SS springs on my 2013 PPV. Does anyone have any regrets after using these springs for a bit? Assume these are more than cosmetic and the car handles better? Thx!
2013 9C3, DoD delete, BTR Stg 1, Kooks 1 7/8, Rotofab, 3.27 Diff, VMR 810 wheels (staggered), King Springs (lowered), oh and a D1SC.
Post by Pursuit » Sat Apr 22, 2017 1:28 pm
No regrets at all. I was glad to get rid of the heavy/stiff rated springs in the rear. The originals were designed with the assumption of a lot of gear and electronics in the trunk. The car still has great handling. I also had the TPMS thresholds dropped down so that I could run 35 psi without getting the warnings. I haven't talked to or seen anyone that hasn't liked this upgrade.
Regards,
Hzgray
Post by Hzgray » Sat Apr 22, 2017 2:03 pm
Thanks. I was hoping to hear this!
Post by xcidmigs » Sun Apr 23, 2017 1:29 pm
Pursuit wrote: I also had the TPMS thresholds dropped down so that I could run 35 psi without getting the warnings
HOW DID YOU DO THIS?
P.S. I have the SS springs/later shocks and 1LE rear lower control arms on my 2011 and the ride is much less harsh than stock despite using 19" tires.
cal30_sniper
Post by cal30_sniper » Sun Apr 23, 2017 2:03 pm
Whats the advantage to the 1LE control arms? Was the swap so you could run wider rims, or do they have some kind of improved suspension geometry?
-2011 Caprice 9C1 (Gone)
