CTSV2 wheels?
CTSV2 wheels?
i have the original set from my 09 V. i'd rather ave the cash but if they don't sell maybe i'll put them on the PPV. does anyone know if it they fit (pattern/spacing/etc)?
regards,
alex
vectorbundle[AT]gmail[DOT]com
2009 gray CTSV modded 700rwhp
2012 black 9C1 caprice PPV 3.45 diff
- eagle-co94
Re: CTSV2 wheels?
As far as I know they fit just fine.
Re: CTSV2 wheels?
rears with 285s didn't fit, flush against wheel well on the inside.
regards,
alex
Re: CTSV2 wheels?
a proper spacer setup could fix that, I'd think....
http://www.hrsprings.com/products/trak/" onclick="window.open(this.href);return false;
http://www.hrsprings.com/application/se ... /1516/2013" onclick="window.open(this.href);return false;
20, 22, 25, 30 mm spacer/adapter (Camaro application)
H&R does make thinner spacers http://www.trakplus.com/" onclick="window.open(this.href);return false; - similar to those below (from Motorsport Tech), but not for the GM Zeta wheel hub ID/OD
custom spacers:
http://www.motorsport-tech.com/wheel_spacers.html" onclick="window.open(this.href);return false;
http://www.motorsport-tech.com/wheel_adapters.html" onclick="window.open(this.href);return false;
custom spacers:
- eagle-co94
Re: CTSV2 wheels?
Looks like I'll have to fit one of my fronts and one of my coupe rears to see how they fit.
- eagle-co94
Re: CTSV2 wheels?
I ran H&R Trak+ spacers on my MINI Clubman S on the Autobahn at speeds up to 145mph and on the Nurburgring throwing it into curves. I always look to H&R first for wheel spacers.
Re: CTSV2 wheels?
I just picked a set of sedan wheels and the front tires rub on the pass side strut and the drivers side has maybe a 1/8 in... Anybody else had that issue? Seems like it has quite a bit more - camber on the passenger side front and rear. I thought it seems to stick better going left lol is this normal on these? My car has 25k now and is nice and tight yet and was really hoping these wheels would bolt right on
2011 9C3
2013 9C1
2013 9C1
Re: CTSV2 wheels?
use a 3mm spacer on the fronts
Re: CTSV2 wheels?
Would you need to run longer studs with 20mm spacers? I bought the car with 285's on CTSV's so I thought they fit until I noticed wear on the inner fender liner. Now I'm concerned.
Jim
Jim
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
Re: CTSV2 wheels?
Unless it’s all the time, don’t be. We’ve ‘polished’ the inner fender wells of our 3rd Gen Firebird with Hoosier slicks every time we install a new set. They also rub on the LCAs a bit. Except for the time we ran new tires after the fresh mini-tub install, and discovered a bead of welding rod sitting proud , we’ve been fine.
