steel wheel question
Does someone have a weight on a steel wheel with no tire, just the rim ??? thanks
Re: steel wheel question
32 pounds
2007 Saudi/UAE Caprice
2013 Camaro SS M6 "Panther"
The wheel and a brand new, unworn RSA is 60.8 lbs, so the factory tires weigh 28.8 lbs if anyone cares.
thanks for the info.....just thinking that a lite set of aftermarket wheels would sure shave some pounds off the car. This should help with the handling some
id say the wheels and tires are 65-70 lbs easy
Read exactly 2 posts up from yours. I weighed mine.Maxspeed96ct wrote:id say the wheels and tires are 65-70 lbs easy
