List of stock Rims that bolt on without mods? or with small
Maximuss
Post by Maximuss »
Is there a list of ALL the Rims that can bolt on to the Caprice PPV? without any issues.
G8? Malibu? Camaro? SS? I have bee seeing different posts but not a complete list.....and maybe some pics.
Adam Haack
Owner- CarmaHawk Creations
9-time Caprice owner
1998 Tahoe 2door-2wd
2012 White PPV 6.0 SOLD :(
1991 Caprice LT1 swapped “Capricious”
t-shirt and vinyl decals maker
1991 Olds very Custom Cruiser 350...
1996 Roadie convertible wagon
Re: List of stock Rims that bolt on without mods? or with sm
Here's a list from SS Forum:
http://www.ssforums.com/forum/wheels-ti ... 2-0-a.html" onclick="window.open(this.href);return false;
Your quest is WIDE open...all you named....and more.
Current generation Impala/LaCrosse
Previous generation Regal & Malibu
Gen5/Gen6 Camaro (offsets are NOT ideal for Gen6 to work)
G8, of course, and SS sedan
Cadillac ATS/CTS - current generation and 2nd generation CTS
Some BMW wheels may work--offsets in the +35 range and higher
Depending on source, hub-centric rings may be necessary - there are some who use C5/C6 and possibly C7 wheels, although pattern is not the same, and hub centric rings are needed. "Floating seat" lug nuts can take care of the wheel bolt circle (120mm vs 120.65mm - aka 4.75")--it's a very small difference and many do it and get away with it, but I just wanted to get the facts out there.
You may get other responses that differ/disagree--so be it.
Black6
Re: List of stock Rims that bolt on without mods? or with small
Post by Black6 »
ATS wheels will not work. Even though it’s the same platform as the Camaro 6, the idiots at GM made the ATS have the same lug pattern as the first CTS. So it’s not 5x120.
Keep in mind if you brake swap, wheels that might have fit before may have issues with new brakes.
Only way to be 100% sure the wheels you want fit on a car is to see them on a car and then make sure someone isn’t using spacers/adapters/hopes/dreams to hold them onto the car.
Black 2014 V8
Urban Whale
Post by Urban Whale »
ATS-V rims are 5-120, so they will work. All other ATS’s are 5-115
