Truck rim? 5 lug
No Moa
Re: Truck rim? 5 lug
Post by No Moa »
that good to know, i'll be on the look out for some 20s, someday I might do the brembo upgrade. I assume that applys to any rims, not just Camaro or CTSV?
2014 Caprice PPV silver
2017 Ram 3500
2002 CETA trans am
1995 9c1
1977 Trans am SE 4spd.
1978 trans am 400 4 spd.
No, the caliper is designed to fit over a specific-width rotor (30mm for 345) and the caliper mount is designed for and mounts on the suspension upright/knuckle at a corresponding distance to match the rotor diameter.
If you dig into it, you'll find there are also Brembo calipers on 321mm rotors on the Alpha platform--current Camaro, ATS & CTS, at least. The caliper for the 345mm rotor package will not have the same mounting "ear" length (radial distance) as the caliper for the 321mm rotor package, as they all use the same basic knuckle.
No Moa wrote:that good to know, i'll be on the look out for some 20s, someday I might do the brembo upgrade. I assume that applys to any rims, not just Camaro or CTSV?
No, 20's are not essential--the 355mm Brembo package fits behind stock PPV steel wheels, for example. There are plenty of 18" or 19" wheels that work with the 355mm rotor/caliper, it's just a matter of knowing/discovering what clears both radially & laterally.
Here's my current 18 x 9 setup--full disclosure, I do have a 2.5mm hub-centric spacer, but the wheel DID clear without it, although the spoke-to-caliper clearance was VERY close, so I wanted some insurance, and for obvious reasons, I was not going to create clearance by modifying the calipers.
PPV RF new rotor and caliper.JPG (39.91 KiB) Viewed 5756 times
new wheel.JPG (51.01 KiB) Viewed 5756 times
Post by Pursuit »
Bill,
I like the whole combination. The brake package, car color and rim choice. Good job!
Regards,
high praise--thank you!
