snow tires
cerbomark
snow tires
Post by cerbomark »
Anyone using a winter tire? What tire and rim? Some of us are in the snowbelts.
2016 C1
cerbomark
Re: snow tires
Post by cerbomark »
and how will these fit our car?
Offset:45mm
Backspacing:5.91"
Bolt Pattern:5-114
using for snow tires.
2016 C1
Oldblue68chevy
Re: snow tires
Post by Oldblue68chevy »
Cant help on the backspacing of those rims but our cars use 5x120 bolt circle so those wont fit.
2011 PPV 9C3
cerbomark
Re: snow tires
Post by cerbomark »
Oldblue68chevy wrote:Cant help on the backspacing of those rims but our cars use 5x120 bolt circle so those wont fit.
Thanks, I thought so but they came off a G8. Guess they are not the same or guy gave me wrong numbers.
2016 C1
lastcall190
Re: snow tires
Post by lastcall190 »
Can't help with the wheels but I have some General Altimax Arctic on my Crown Vic and put them on my wife's car. I went thin, 225, and have had incredible success thus far. If I were to put snows on the Caprice I would absolutely go with them again. And as stated, 5x120 is what you'll want. I believe I've seen instances of guys putting different bolt pattern wheels on the G8s, but maybe the 120.25 or whatever it is... 114 seems like a bridge too far.
EDIT: Saw your WTB ad for 4 stock wheels so I could imagine that that is the route you're going.
cerbomark
Re: snow tires
Post by cerbomark »
Yea he gave me wrong link. 5x120s, whats the center bore size got to be? I imagine everyone using hub rings?
Yea, I d like OEM steelies.
2016 C1
lastcall190
Re: snow tires
Stock center bore looks to be 66.9
from here:
https://www.newcaprice.com/forum/viewto ... 8&start=10" onclick="window.open(this.href);return false;
Can't comment on rings... I'm on plain jane steelies right now.
l77
Re: snow tires
Post by l77 »
Goodyear Ultra Grip Ice WRT 225/55R-18 on factory wheels ~
x-pro1/x-pro2/x-t30
8/12/18/35/60/90mm
cerbomark
Re: snow tires
Post by cerbomark »
Thanks, 5x120
offset 46mm
center 66.9- (70.3)
sums it up.
235 55 17 can replace stock 235 50 18 s if you want to drop down a size for snows.
2016 C1
Re: snow tires
cerbomark wrote: 235 55 17 can replace stock 235 50 18 s if you want to drop down a size for snows.
You sure about that? I thought we had to have 18" wheels to clear the front brakes.
