GM Part Number for the Caprice PPV 2011 Hub Caps (9C1 Impala Style)
8rody
Re: GM Part Number for the Caprice PPV 2011 Hub Caps (9C1 Impala Style)
Post by 8rody »
My ordered GM 09593297 (9C1 Impala) Hub Caps arrived.
As per Maurice's photos, they bolt up perfectly.
There is a minor difference in the PCD, however all promo photos from the PPV 2011 seem to also depict the PCD being a bit off.
Lug nuts should clear the Hub Caps, but worst case scenario I can drill out the lug holes in the Hub Caps to clear.
Here are a few pictures to give you an idea. Makes the PPV steel wheels look more NASCAR/Days of Thunder than the standard PPV ones. Matter of taste I suppose.
Image Image Image Image ImageImage Image Image Image
- Brody
The PCD difference is 120mm vs 115mm - 2.5mm radially, about 1/10 of an inch (0.1")
The one thing you don't want is for the center caps to have an "orbit" - hopefully they mount up and are concentric to the wheel, and the lugs can be torqued without distorting the cap in any way.
