Steel wheel offset confirmation...
Posted: Fri Apr 12, 2019 3:17 pm
by 20129C1
Hello all,
I realize it's only 2MM difference, but can anyone confirm if the OEM 18" steelies are 46MM offset or 48MM offset? A search here has both. I'm trying to mount a set of Holden wheels, but they won't clear the Brembo calipers. Trying to compare the two wheels' specs and go from there.
Thanks!
Re: Steel wheel offset confirmation...
Posted: Fri Apr 12, 2019 4:13 pm
the offset has nothing to do with clearing the brakes , its all in the wheels design
the steel wheel is lucky it clears the brembo's
most factory holden wheels were not made to clear brembo's
Posted: Fri Apr 12, 2019 4:30 pm
by 20129C1
s/c'd cav wrote: Fri Apr 12, 2019 4:13 pm the offset has nothing to do with clearing the brakes , its all in the wheels design
I was hoping that wasn't the case. :( Mechanic said spacers might work, so gonna try to head to the tire shop tomorrow and see what if anything they might come up with.
Posted: Fri Apr 12, 2019 4:38 pm
which wheels do you have ? pictures ?
Posted: Fri Apr 12, 2019 5:05 pm
by 20129C1
This old thread, fifth post down....
http://newcaprice.com/forum/viewtopic.p ... 91ac56325b
Posted: Fri Apr 12, 2019 6:22 pm
are they a 18x8 ? i would guess they are the same or very close to the same as the 18x8 g8 v6 wheel , if you search the g8board , you should be able to find how much spacer they needed for the front wheel to clear the caliper
Posted: Fri Apr 12, 2019 11:36 pm
by 20129C1
Yes, 18x8. Same hub bore. Ok, good to know. I'll look there.
Thanks!
