Do 20" wheels from a 2019 V6 Camaro fit?
Found a very nice set of wheels from a 2019 Camaro that are 20x8.5. Just wanna see if someone knows for sure that they'll fit my 2014 Caprice? Thanks!
Re: Do 20" wheels from a 2019 V6 Camaro fit?
All 4 are 8.5"?
That is the front wheel, which is +25mm offset - in other words, compared to a stock wheel, they push out or "poke" another 20mm +/- compared to the stock wheel, PLUS they're another 1/2" wider. They'll work on front, may not work so well on the rear.
Base Alpha Camaro wheels are 18x8.5 +32mm. No issues on front, create rub at rear (255/45-18) if fenders aren't rolled.
OE SS sedan (19") wheels, for reference, are 8.5" +48mm and rear are 9.0" +57mm....set in to stay well clear of wheel opening sheet metal.
So I should get a set from an SS?
They fit!
- 3F078477-7EEE-4D52-BC2D-87EBB7D6D072.jpeg (4.84 MiB) Viewed 4842 times
