New to the forum from the Texas Gulf Coast. Recently picked up a white 2011 Caprice with ~38,000 miles that had digested too much water, from a county fleet auction. From the looks of the interior and lack of holes for a partition, only one hole in the trunk, no window tint and minimal decals, it appears that it was not used by the sheriffs dept.
I popped the heads off of it and found one rod was bent and twisted and the piston was shattered and wedged in the bore. Unfortunately they let the car sit too long and a couple of the bores had some pretty deep pits in the cylinder walls, plus I am not 100 percent the cylinder that had the rod/piston damage did not get cracked.
Found a ~26,000 mile 2013 model in Tennessee that was hydroplaned which had front and rear body & structural damage. The car is up and running and I am in the process of stripping the 2013 for spare parts for the 2011. It is pretty amazing of the differences in the parts between the 2011 and the 2013 as I work on a spreadsheet of the part numbers of the parts that are still usable.
I have been taking plenty of pictures as I dismantle the 2013 as a reference for some of the hidden fasteners and clips. I keep vehicles for many years and as you hit the late 50's, the memory is just not the same as when I was in my 20's and 30's.
David
New member from Lake Jackson, Texas
Re: New member from Lake Jackson, Texas
Welcome to our happy little group! Yep, your car is not the first that's tried to play submarine. EagleCo94 has one in the same boat, 2012 9C3 with a hydrolocked motor but his car only had 760 miles. He's supposed to be swapping the motor in the next week or two so there might be more parts afoot
Good luck on the repairs and again welcome!
Ahh, another member in southeast Texas!! Welcome.
If I had reason to pull the engine out of mine, I'd seriously-consider removing the DOD parts, and upgrading the cam, adding long tubes, throwing a converter at the transmission, etc. Good luck on your conversion, and please let us know when you start jettisoning parts you no longer need.
