2016 Southern California
Re: pumped
SSpeedracer wrote:Springs
KHFL-151SL Front
KHRL-152HD Rear
Nice color!! That looks very close to the color of our DGGM 95 SS. I bet those would look pretty cool side-by-side!! ;)
SSpeedracer
Re: 2016 Southern California
Post by SSpeedracer »
Got the Caprice aligned. Had pulled slightly right and the steering wheel was not centered by 45 degrees since purchase.
The alignment computer did not have a recent model caprice in the data base so I had the mechanic use Chevrolet SS 14-16 specs.
The car is lowered on King Springs KHFL-151SL Front KHRL-152HD Rear and SS specs could not be met without installing shims and offset bolts. So using existing hardware ended up with:
L/R
Front Camber -1.1/-1.6
Front Toe .08/.05
Rear Camber -1.1/-1.5
Rear Tow .17/.07
Camber was minimized as much as possible but outside spec because the car is lowered. Also, the tank was full.
Funny thing, the Caprice got stuck on the lift when coming off, lowered and long wheel base.
2016 Caprice
SSpeedracer
Re: pumped
Thanks. I like it too. My son is shopping for a Caprice and figured out how rare a retired green 16+ is to find.
2016 Caprice
SSpeedracer
Pictures here http://newcaprice.com/forum/viewtopic.php?f=21&t=2885" onclick="window.open(this.href);return false;
Front corner turn lights, very good, require resitors:
CREE LED Light 30W BAY9s H21W Amber Orange Two Bulbs Park Backup Marker Signal
Backup, excellent
LASFIT T15 LED Reverse Backup Light Bulbs 921 912 6000K White for GMC Ford Chevy
2016 Caprice
