New 2013 Chevy Caprice
worth40mill
Post by worth40mill »
Hello fellas, I just got a new to me 2013 Caprice PPV i do have plans to do a console swap and little touches here and there. i have bought some G8 black interior pieces to completely black out my interior. i do have a few questions about some on the things i have heard and wondering if its still true.
Question 1: Has anyone been able to switch ignition cylinder lock to be able to change keys and maybe even get the flip key?
Question 2: If you have any console swaps could you add pictures? i have bought the G8 console and seems like it will work perfect but does have a lot of pieces.
Question 3: Has anyone been able to unlock the radios and also what rear view cameras did you guys buy and from where? also where you guys getting the extra wiring harnesses needed for the iphone and aux connections.
lastcall190
Re: New 2013 Chevy Caprice
Post by lastcall190 »
Welcome and congrats.
As for your questions:
1) flip key has been done do a search here. I think steve walker has a post about it.
2) search for pics here. Lots of members did the swap and posted pics. Yes it is a lot of pieces!
3) Chris White from WAMS for the radio is whom I and many others used. The cables? Again, steve Walker
I know search is redundant and an annoying answer probably but search via Google:
"G8 console site:www.newcaprice.com" for instance for the console pics. Good luck with the car
GammaFlat
Post by GammaFlat »
I did the flip key recently and I "caboosed" onto Steve's thread. http://newcaprice.com/forum/viewtopic.p ... 0ad5847937
You can get the flip keys for less than 50 bucks (for 2) on eBay.
As mentioned in the link above, there's an "imobilizer" device that looks for a small chip in your key. You can avoid having to "re-program" it if you can successfully dig it out of your original key. I did a lot of bleeding attempting to re-use the old one (long story, not proud). I recommend just use the new one that comes with the new key. Re-programming is very straightforward. Also, reprogramming the buttons on your remote is easy. The third part is cutting your key. I re-used my key and removed the new "blank" from the "flipper". Good luck and ask questions if you have them. Enjoy!
Turbopowered68
Post by Turbopowered68 »
@ worth40mill Looking forward to your build don't forget to add pictures.
2014 Caprice V8
1986 GN
1968 Chevelle
